Tool Talk Discussion Forum
David Brown Tractor
Dale
06-22-2004 15:36:38
I am having a problem with the hydrolics on the back of the tractor'Sometimes it will work,sometimes not.Any idea were to look???
rod
06-27-2004 06:43:50
 Re: David Brown Tractor in reply to Dale, 06-22-2004 15:36:38
lots of places to check the relief valve could be sticking I have all the manuals copied drop me an email or visit this group message board http://groups.yahoo.com/group/dbtractors/
regards
rod
rhudson
06-22-2004 19:35:36
if it were not for hydraulic problems, the david browns would have no problems at all. by "some times" do you mean they work when cold but not after the tractor has warmed up? probably hydraulic pump clearances opening up or leaky hydraulic cylinder seals. otherwise, do you know how to use the complicated valve system that came on some DB's? my 990 has 6 adjustments and levers for the hydraulic system. you may need a manual. go to case page and ring ELMER, he is the expert.
