Tool Talk Discussion Forum
T_Bone, a question.
Slowpoke
06-19-2004 01:07:02
About 5 posts back, Mr Marlen describes some equipment to do TIG welding. My having no experience with TIG, what is your opinion of this setup? It seems rather inexpensive, but will it do the typical TIG job?
Thanks for your help.
T_Bone
06-19-2004 20:33:29
 Re: T_Bone, a question. in reply to Slowpoke, 06-19-2004 01:07:02
Hi Slowpoke,
Yes that's called scratch start Tig. Used in the field alot as it's difficult to use a foot rheostat. Now that we have thumb amperage controls that will probably change.
Any way you set the average welding amps required then control fine heat with travel speed. You use straight polarity.
To start the arc, you lightly touch the tungsten to the base metal then quickly pull away about 1/8" then start forming the molten weld puddle hence the name scratch start Tig. Each time the tungsten touchs the base metal then it gets contaminated with the base metal.
With a HF unit and foot rherostat the arc jumps from the end of the tungsten to the base metal for a clean arc start with very little tungsten contamination.
Cheap Tig set up as all you need is a Tig torch and a flow meter. The torch hot lead has a copper eyelet that is clamped into the electrode holder. The Tig torch has a slide valve on the torch for gas on/off or some don't have a gas valve and you shut the flow meter off/on as needed.
Another lead type uses a brass fitting to clamp on the electrode holder with a threaded coupler for the gas line.
100% AR cover gas works well for 90% of the common metals, SS, CU, PB, carbon steel.
I have no idea what you get for $29. The parts to a typical Tig torch are;
1) Torch head
2) ceramic cup for cover gas direction control
3) collet & collet body clamps the tungsten in the torch head by the end cap pushing the collet into the collet body thus the collet holds tight to the tungsten. 3/32" works well.
4) end cap. A long end cap allows full length tungsten to pretrude into the end cap. A short end cap allows you to get into tight areas and uses 1/2 of a full length (7") tungsten.
5) weld lead with gas line.
Nothing wrong with scratch start Tig and thats what I still use. I can't see the need for more expensive equipment for no more Tig welding I do.
T_Bone
Slowpoke
06-24-2004 00:30:51
 Re: Re: T_Bone, a question. in reply to T_Bone, 06-19-2004 20:33:29
Hmmmm... This looks like it requires more study before spending $$.
Thanks, T_Bone
