Tool Talk Discussion Forum
Grease Guns
Kevin S.
06-17-2004 21:53:15
Between my father & father in law, they must have 10 "grease guns". I grabbed one the other day, inserted a refill tube, and tried to grease dad's 8N. It wouldn't pump. It seemed like it wouldnt prime, if you will. pumping the handle seemed to have no resistance. Tried several others with similar results.
Do these wear out? is there an easy fix (bad seal)or is there a trick Im not seeing here???
Thanks
KDS
smurph72
06-18-2004 19:07:54
 Re: Grease Guns in reply to Kevin S., 06-17-2004 21:53:15
What position are the grease tubes stored in? Used to sell the stuff and the service truck mechanics would put a box on 10 tubes on its side in the service body with their tools for easy access. All the bouncing in the truck aggravated the problem you've got by creating an air pocket the length of the tube.
Store tubes on end to eliminate this.....
dcm
wolfy
06-18-2004 18:55:02
Sounds like you forgot to remove one of the end caps of the cartridge. I usually do that about once a year.
Chester
06-18-2004 17:31:39
Have always used bulk grease. Just stick the tube into the grease and pull up like a suction gun. Grease loads instantly with no mess. Cut grease off flat at top of the tube and install on pump. Seldom is there an air problem. If there is, loosen the pump a turn or so to dispense it. Have always used the cheap import guns also.
Jon H
06-18-2004 11:52:31
My best luck for purging air after a cartridge change is to leave the head loose about 1 turn then release the plunger and tightn head after a few seconds. I also leave the grease hose screwed finger tight in the gun head,that way it is easy to remove the hose without tools and pump the gun untill the air bubble is purged from the pump. reinstall the hose finger tight and you are good to go.
txblu
06-18-2004 08:27:54
Wanna date yourself, are any of them too small in diameter for the cartridge to fit?
My first was like that. Bought it before they had cartridges (or I knew of them being available). Had to glob the grease in by hand. Talk about a joke. Glad I wasn't a farmer then. Nothing would have been greased.
Course when the cartridges came out, they wouldn't fit existing guns so you had to buy another gun.
Marketing guy was doing his job.Pfft.
Mark
Mark
Davis In SC
06-18-2004 21:12:53
 Re: Re: Grease Guns in reply to txblu, 06-18-2004 08:27:54
Tx, your post brought back old memories. My Dad had an old grease gun that had a zerk fitting to fill it. He would send me on my bike to Jack's Esso station. For a Quarter, Jack would let me fill it with his air-operated grease gun. That way no air got into the gun, & it saved a lot of soap trying to clean our hands after filling it from a can of grease..... . Regards, Davis
txblu
06-19-2004 05:42:53
 Re: Re: Re: Grease Guns in reply to Davis In SC, 06-18-2004 21:12:53
So that's how you filled them! Man I mean as you apparently know, that was the biggest mess.
Best,
Mark
hay
06-18-2004 09:06:13
i handpacked grease for many years. what a PITA that was. everytime i needed to grease something the darn gun was empty. finally got to using tube grease and i ocassionally have the problem with air pockets, but my gun has a bleeder valve on top and it helps some. best remedy is to pull out the plunger and RAM it hard a few times and that usually helps the most and then for the rest of the tube the greasegun works normally. some grease brands (like TSC) seem to be more prone to air problems than others.
txblu
06-19-2004 05:45:22
 Re: Re: Re: Grease Guns in reply to hay, 06-18-2004 09:06:13
I agree with you on the always empty. I've noticed my cartridge guns are that way too. Must be somthing to the fill process...er ah like a big mess regardless of how careful to keep it off you and the gun.
Mark
Ron
06-18-2004 03:06:22
Ask them to show you the procedure for "burping" the air lock you have between the head and head end of the grease tube. Different for different makes of guns.
Vern-MI
06-18-2004 03:03:18
It is air bound and you can't pump the air out so you have to bleed the air out with the spring piston behind the grease cartridge. When the cartridge is first inserted do not tighten the cylinder until the air has had a chance to bleed out and the grease begins to pump. You may have to loosen the hose or pipe at the discharge of the pump to get it to bleed properly. Old grease in the gun tends to dry out and is even harder to move and get the new grease cartridge to start pumping.
