Tool Talk Discussion Forum
AIR COMPRESSOR
MMRTI
06-14-2004 19:24:30
I purchased a small portable compressor at a sale. It seems well made but no motor. Westinghouse pump model 2G serial 109708. Does anybody know what minimum size motor is needed. I need consider electic capacity in some of my buildings. Thank you for any information.
Kendall
06-18-2004 08:15:04
 Re: AIR COMPRESSOR in reply to MMRTI, 06-14-2004 19:24:30
Dont know the brand name on the actual compressor my Campbell Hausfeld uses but I've seen it on a varity of air compressors ranging from 1.5 to 5 hp.(real hp, not the smoke-n-mirror "peak" hp they try to snow you with these days) Im sure its just a matter of pulley size on the motor so as not to bog it down. Bigger motor = bigger pulley = more CFM. A smaller motor/pulley combo will still build up to the same pressure, just take a little longer and will run a lot if you do anything that requires lots of CFM.
