Tool Talk Discussion Forum
GPS Systems
BobInMN
06-10-2004 19:39:37
Does anyone have any idea of the cheapest GPS system you can buy that is accurate to within a couple of inches for elevation? I'd like to have a handheld system that doesn't require a base station if thats possible. I've got one now that cost $150, but is only accurate to within 125 feet for elevation.
Gene Davis (Ga.)
06-14-2004 20:36:30
 Re: GPS Systems in reply to BobInMN, 06-10-2004 19:39:37
Don't you need a pretty good government security cleareance for that type of accuracy?
david - OR
06-11-2004 09:56:45
I'm reminded of the old joke. "How can you measure the height of a building with a barometer?"
In your case the cheapest approach would be to go to Kmart and buy a roll of string. Climb to the top of the object you wish to measure, attach the GPS to the sring, lower the string to the bottom, tie a knot in the string to mark the top, pull the GPS back up and measure the string.
But seriously...
There are NO single unit GPS systems with a vertical accuracy of "a couple of inches". It turns out that the Z axis is the least accurate GPS position, and even high-end receivers with WAAS correction and time averaging can only get you within a couple of feet.
To get down to a couple of inches vertically takes a survey grade unit with a base station and a radio link between them. You may additionally need 30+second acquisition times and/or post-processing of the data to find out where you were. If you are on top of a high mountain with excellent sattelite reception you can consider carrier phase processing instead of DGPS -- but you will need 45 minutes to get down to "a couple of inches". None of this is a cheap proposition -- figure $10000 or more.
"A couple of inches" equates to 5 cm or .05 meter. There are vendors of survey grade equipment that will rent you gear with accuracy in that range for about $300 per day. Take a look at the attached URL to get an idea of what you are trying to get into.
