Tool Talk Discussion Forum
Ok. Don't laugh at this question. What are
James in North
06-06-2004 07:47:46
end mills used for? Thanks.
Davis in SC
06-06-2004 11:53:35
 Re: Ok. Don't laugh at this question. What are in reply to James in North Carolina, 06-06-2004 07:47:46
End mills are used in various types of milling machines to cut metal & other materials. They are called end mills because they cut on the end , as well as the periphery. They come in many sizes , diameters from a few thousandths , up to several inches. Forms avaliable include center-cutting, ball nose, tapered, as well as many special types. Most are made of either high-speed steel or tungsten carbide, with several wear-resisting coatings available to increase the life of them. As a sidenote, endmills are expensive !!!! Regards, Davis
TomH
06-06-2004 08:45:36
Kind of the metalworking equivalent of a woodworker's router bit. In fact, end mills make good router bits if they fit in the collet
DL
06-06-2004 16:08:41
 Re: Re: Ok. Don't laugh at this question. What a in reply to TomH, 06-06-2004 08:45:36
and... as a side note... we sometimes use router bits in our lathe and milling machines! One job we do requires a "ball" end to be cut on the end of a piece of 3/8" stainless round bar... we chuck a 3/16" carbide roundover (router) bit in the tool holder and the roundbar in the lathe collet and cut away!
Ron
06-06-2004 09:00:55
You are a gentleman in a sea of loonies.
And yes, carbide end mills are often used exactly as you describe, especially for applications where a cutter with repeatable high precision is required to make it through an entire shift or longer... making oak flooring is an example.
CJ
06-06-2004 08:43:00
See you are not so dumb as you thought . They do not know either!!LOL
Scottp
06-06-2004 08:28:59
milling ends.
Bridgeport Bob
06-06-2004 08:00:57
Hahahaha LOL geeez help me , I'm gonna wet my pants, turn a hose on me , I'm gonna choke . hahahaha
