Let me start FRESH as I may not have been clear in asking my question ORIGINALLY.IF YOU ARE NEW TO THIS QUESTION PLEASE SEE MY ORIGINAL POST OF JUNE 4, 2004 FOR DETAILS. ORIGINAL QUESTION:.....I have a well and a EXTROL tank. The output pressure at the faucets/shower is less than desireable. The tank is about 18 years old. It has a valve stem at the top and the pressure at that stem is 28psi when the tank is empty. There is a SQUARE D cut in/out switch. The in pressure is set @30 in off @50. I was trying to keep my original question simple, however, since there are such deep thinkers out there here's the REAL reason I asked the question. I am considering installing a water conditioner and the mfg suggested increasing the OVERALL SYSTEM pressure as that unit will DECREASE it by 10psi. I have lived with the current pressure for 18 years (HASN'T CHANGED IN 18 YEARS), however the pressure is just nominal and has been this way since I had the well drilled and the system installed. We have just learned to live with it, however CAN'T AFFORD a 10psi DROP. TO ADDRESS SEVERAL OF YOUR INITIAL QUESTIONS/SUGGESTIONS: The pressure is relatively the same at ALL outlets. ALL Pipes are fine. NO galv/iron pipes, ALL are copper. NO leaky hoses. Water filter has been on the system since new, has a new cartridge and I have verified that IS NOT the problem. I agree with RON, pump has nothing to do with the pressure at the outlets, also with DON who said if baldder holds 28psi its good....Since it holds 28psi I assume it is good. Now with all that said, can anyone offer a suggestion to my ORIGINAL question..... IS THERE ANY WAY TO INCREASE THE PRESSURE AT THE OUTLETS, FAUCETS/SHOWERS,ETC?????
