Tool Talk Discussion Forum
Lincoln 225 AC welder problem
Jim-IL
06-03-2004 17:51:01
I bought a Lincoln 225 welder at an auction the other day and I'm having a problem with the dial. It's almost impossible to change the settings. Is there some adjustment on this or did I buy a lemon?
Fred OH
06-08-2004 07:47:51
 Re: Lincoln 225 AC welder problem in reply to Jim-IL, 06-03-2004 17:51:01
Take the cover off the machine and look at it...someone may have tried to switch it under power and arced it...making it hard to turn. A bit of dressing with a file or die grinder would help along with some resistive grease. Also, while the cover is off, take an air hose to it...do it once a year and it will last longer. Fred OH
Ben in KY
06-04-2004 06:00:21
The parts are some sort of plastic, I used silicon liquid lube on mine. The knob has a setscrew on it to remove it, you should then be able to lube the mechanism.
wdtom
06-03-2004 18:14:54
I would take the cover off of it and seeif you could clean or lube the switch/dial. These are good welders for a basic welder.
don perkins
06-03-2004 18:30:39
 Re: Re: Lincoln 225 AC welder problem in reply to wdtom, 06-03-2004 18:14:54
on those lincoln welders yiu have to pull out on the knob to turn it. if you don't it will ruin the switch.
