Tool Talk Discussion Forum
Cambell Hausfield MIG question
Bill
06-03-2004 14:51:00
I have a Cambell Hausfiled wire welder. Flux wire only. Is it normal that the trigger on the wire gun only controls the wire feed? Should it also control as to wether or not the wire is hot and ready to weld with? Do other manufacturers work the same way, or are some units built so that both the feed and current to the wire is controlled by the switch? Has anyone modified a unit whereas the trigger on the gun controls both functions?
Thanks..
Bill
Buck
06-03-2004 17:21:31
 Re: Cambell Hausfield MIG question in reply to Bill, 06-03-2004 14:51:00
Hi Bill. I'm not familiar with the Cambell Hausfield wire feeder, but I ran Lincoln's LN-22 for years. They were always hot. Then the LN-25 came out, and you could have a contactor kit installed. This would allow the trigger to controll the power at the tip. Maybe Cambell Hausfield offers this?
Bundy
06-03-2004 16:27:40
Yes some are hot all the time.
BrokenFences
06-03-2004 18:43:33
 Re: Re: Cambell Hausfield MIG question in reply to Bundy, 06-03-2004 16:27:40
My Lincoln weld pak is controlled by the trigger; squeeze and it feeds hot wire. It runs off a GOOD 20 amp 115 volt outlet, and is very versatile.
