Tool Talk Discussion Forum
Best Metal Cutting Chop Saw ?
Chris(WA)
06-01-2004 21:21:01
What have you guys had success with in terms of usability and life? We have a Milwaukee at work that I would not own myself on a bet. I normally like their tools but this one is poor. The table angle clamp adjustment is hard to use and flimsy, broke soon after we got it. I want one that has a good table for cutting angles. Anybody seen one that will cut angles by moving the cutting head like a wood power mitrebox instead of clamping the work at an angle?
Let me know what you think. Thanks?
rick
06-02-2004 07:12:48
 Re: Best Metal Cutting Chop Saw ? in reply to Chris(WA), 06-01-2004 21:21:01
Chris; If you do much cutting at all and is mainily in the shop then I would go with a metal cutting band saw instead. I went thru chop saws at least one a year,Makita,Blackdecker.Jepsen,etc. I finally went to a Band saw and would never go back especially if you want the angles to cut like you mention with the head of the saw to move. I have a Ellis brand dry saw. I love it, saw head moves to cut the angles,can cut up to 12" square steel. Blade I get about 2 years out of. Best move I made for steel cutting saw. No more basically burning the steel cut. Steel is hardly warm after cut also. Rick
bob
06-02-2004 06:40:25
have a Dewalt and really like it it is not the cheap one does good on angles/ at work we had a mill and had same problem with vise
Cliff (VA)
06-02-2004 06:36:43
You might want to look at the metal cutting saws that use carbide blades such as the Dewalt DW872. We use one at work and I really like it. The cut is cleaner than an abrasive blade and cooler.
More money, but less mess and fuss. Cuts cleaner and faster too.
Ron
06-02-2004 03:57:20
Saw a demo... machinist clamped in a piece of cold rolled bar stock and cut perfect pieces as thin as a dime, it uses an abrasive cutting wheel that turns at only a few hundred rpm, very impressive...
http://www.dake-div-jsjcorp.com/cold-saws.html
