Do the major grinding on the front of the grinding wheel like you would doing a chisel. Do the finish on the side of the grinding wheel. (it stay flat in relation to the edge of the bit) For smaller drill bits a drill doctor is really a wonderful tool. Especially smaller than 1/4 inch. On bigger bits do the major grinding getting your angle to 30 degrees and your relief ground in then put a little flat edge on the cutting edge. This makes the cutting edge stronger. This flat needs a bit of relief but can be much flatter than the major grind. You just want a little strip about .030 wide along the cutting edge so the edge doesn't chip away so easy while cutting. Looking at the drill end on, your eyes will be able to tell you very close if your angles are in meeting in the center. Being in the center and having both angles the same the bit should cut straight. If your bit gives you different size chips when you are using it, keep it drilling and turn the drill off so you can see which flute is cutting to much. Then grind it whatever you feel it will take to make the chips even. If the side flutes on your drill bit are dull and your drill is hanging up in the hole, you either have to throw it away or cut it off and put a new point on it where the edges are sharp. Don't use to fine a wheel on the grinder. Fine stones make lots of heat for the metal they remove. Keep it cool with water. Water Works!. Personally I would never use a belt grinder on a drill bit. The abrasive on a belt grinder can only get dull as it wears, which generates heat. A stone sharpens itself as it wears which is the secret to keep cutting material away. Grinding wheels for sharping carbide tools disappear pretty fast but they do because of what they are made of, but also it is the only way for the wheel to have the ability to cut the carbide. If you can find someone who can show you the motion of the drill bit in your hand as you sharpen. The motion is, you hold the cutting edge on the bit at 30 degrees to the side, with the cutting edge almost 90 degrees tothe axis of the wheel face then, thinking of the shank part in your hand, you move it slightly down and out. This is to give you the relief on the heel of the twist so it will clear the material you want to drill. I'm often amazed that the most common error made in hand sharpening is that the drill is hitting on the heel instead of the cutting edge. have fun.
