Tool Talk Discussion Forum
weed eater help please - blade does not turn
Jason
05-29-2004 06:54:13
Interesting thing happened yesterday. While using my gas Ryobi weed eater, the blade/head stopped turning. The engine starts fine, but I can not cut anything because the blade does not turn. Please help - any suggestions?
JP
05-30-2004 08:42:07
 Re: weed eater help please - blade does not turn in reply to Jason, 05-29-2004 06:54:13
If you are using split shaft ryobi, it might have seperated a little at the connector. Check to make sure the engine is all the way on the shaft. check to make sure the head at the bottom has not slipped a little. if these 2 are in their coorrect position, then you need a new drive shaft. A ryobi is not designed to run a blade if that is what you were using. Unfortunatly, unless you can fix it your self, normally you can buy a new trimmer cheaper than having it fixed, unless it is one the higher priced straight shaft.
Roger in SeMO.
05-29-2004 17:28:02
Could be you stripped the gears in the head.
Jason
05-30-2004 07:46:51
 Re: Re: weed eater help please - blade does not tu in reply to Roger in SeMO., 05-29-2004 17:28:02
thank you both for your comments. i assume the next step for me is to take it to a repair shop....unless you know of a way for me to diagnose this myself.
Thanks again
TimV
05-30-2004 08:52:00
 Re: Re: Re: weed eater help please - blade does no in reply to Jason, 05-30-2004 07:46:51
Jason: I don't know your level of mechanical aptitude, but these are not exactly jet turbines. Typically there's a couple of screws holding the shaft on at each end. Pull these and you should be able to see if the shaft is broken--they usually come right out. Typically they have a square shank each end and a flexible shaft. If the ends are rounded off, or if the shaft is snapped, then you've found your problem. If not, you may have to dig deeper--if it's a geared-head model, these might be stripped. Also, the clutch could be broken--usually something else breaks first, but it's not unheard-of for the clutch to break.
Van in AR
05-29-2004 07:16:25
Sounds like you broke the driveshaft.
Van
