Tool Talk Discussion Forum
Metalbestos versus cement black chimney
Steve-Maine
05-27-2004 15:21:02
I am building a 32 x50 shop and would like to know which would be the best? Metalbestos or cement block inside with bricks above roof line chimney. Will probably only use two tanks of oil in winter as it is a hot air furnace and only used while in shop. Thanks
Dusty
05-27-2004 18:02:50
 Re: Metalbestos versus cement black chimney in reply to Steve-Maine, 05-27-2004 15:21:02
Oil must have a class A, triple wall, chimney, same as wood. Gas only needs class B, execpt condensying (PVC). Metalbestos class A retails 6" X 36" $139.00. Class B 6" X 36" $18.00.
51 Pony
05-27-2004 17:44:10
Steve,
With oil, you need the PS model of Metalbestos, not the 'B' vent. The 'B' vent's only good for natural gas. Block will be a lot cheaper for material, but more on the labor. The metal pipe will be more expensive for material, but easy to put up. Need to have the top 3' above anything closer than 10'.
