Tool Talk Discussion Forum
Aluminum corrosion
Nolan
05-27-2004 12:02:59
I've got a couple of well corroded aluminum carburetors that I'd like to clean the corrosion out of. Seems to me that it was here in this board there was some discussion of using a household chemical to clean corroded aluminum. Which of course I've forgotten now. Unfortunately, the search feature is down, and I'm not getting anything doing a Google search.
Any of you folks know of a good chemical to soak badly corroded aluminum in? Coke, laundry detergent, cat urine?
GG
05-27-2004 19:51:10
 Re: Aluminum corrosion in reply to Nolan, 05-27-2004 12:02:59
Commode bowl cleaner will clean aluminim -copper-brass- like new. Just be CAREFUL and EXPERIMENT!!!! Also, beware of the toxic fumes that result!!
Ron
05-27-2004 12:18:49
If the "corrosion" is really brown/black varnish from gasoline, soak them overnight in B12 Chemtool. Available from any auto parts store, get the liquid to soak and the spray to clean out the passages.
If by "corrosion" you mean the normal gray aluminum oxide, Bar Keeper's Friend works great. Any grocery store has it.
harry
06-22-2004 11:31:17
 Re: Re: Aluminum corrosion in reply to Ron, 05-27-2004 12:18:49
I need some information about using 316 Stainless Steel bolts with 6063-t52 alum handrail/ramp systems.
