Tool Talk Discussion Forum
Warn 8074 Winch
ray
05-25-2004 18:34:28
Bought a trailer and it came with a warn 8074 winch. Thing pulls great the problem is I need another winch to un-spool the cable. It has a remote switch for spooling/unspooling. Is the winch suppose to rotate in reverse or something to get line out -- cause currently it don't? I ended up using a come-a-long to get the cable out -- hold the remote "spool out" in one hand and pumped the come-a-long arm with the other. Anyone have an idea if this is normal --with an old 8074 winch??? Been trying to get an owners manual from warn no luck yet.
bubba
12-16-2004 18:06:32
 Re: Warn 8074 Winch in reply to ray, 05-25-2004 18:34:28
I have an old dodge and it came with one of these winches on it when I bought it well that is the reason I bought it but anyways it might be because one of the solinoids is stuck that energizes the motor to reverse I replaced 2 solinoids on minr I think any parts store should have them they are ford starter solinoids I took one off and went and compared it hope this helps
10,000 lb.
05-27-2004 21:31:15
I have a 10,000 lb. warn winch, powers in and out. And as the others have said has a free spool lever. I had problems one time of not powering out. Found I had a broken wire in my remote cable,took me a while to find where it was broken. Fixed it and works fine now.
Van(WA)
05-26-2004 07:03:28
Ray; I have a old Warn 8000(don't know model number)it is at least 30 years old, and it is POWER in and out. would be no good if it wasn't!!
ray
05-26-2004 08:39:42
 Re: Re: Warn 8074 Winch in reply to Van(WA), 05-26-2004 07:03:28
Searched the internet and yep its suppose to have a power out -- as in the winch motor rotates in reverse. Mine just don't rotate in reverse (yet). Thanks for the reply
Bamapuller
05-26-2004 20:36:09
 Re: Re: Re: Warn 8074 Winch in reply to ray, 05-26-2004 08:39:42
My 8000lbs. Warn (don't remember the num.) has power in and power out and it has a clutch so you can free wheel the cable out. If the cable is pulled in tight--power it out enough to get slack in the cable and then disengage the clutch and pull. If the cable isn't wound on the spool nice and neat it can be a bear to get the cable out if it has over lapped itself.
