Tool Talk Discussion Forum
Tire Tools
Pete
05-24-2004 18:31:07
Is anyone familar with the tool bead-cheata sold by value built?Is it a good tool to break the bead or do you have other suggestions to make this job easier?
Rusty Jones/ The Mower Ma
06-04-2004 17:11:00
 Re: Tire Tools in reply to Pete, 05-24-2004 18:31:07
Get yerself an older type of bumper jack, with the flat plate on the bottom and the part that goes under the bumper on the older cars. Then, get a piece of steel angle iron, with each flat side about 4-5 inches wide, about 12-14 inches long,and fairly thick. Drill 6 holes in one flat side, lagscrew this piece to the garage door frame, or weld to a steel post in the garage, or something that won't pull out or off! Set the tire under this, put the bumper jack foot plate on the tire, and the hook under the part of the angle sticking out, and jack away! I've seen this work on several types of tires! Rusty Jones
Van in AR
05-25-2004 20:26:20
I have used a grader blade mounted on the back of my tractor to break beads on tires laying flat on the shop floor, my tractor has a fast hitch and down pressure. I have also used a front loader bucket with equally good results.
Van
KX
05-25-2004 07:37:14
I found the best tire tool in the world and I already had a few of them in my shop, you probably do too. A handy man (tall boy) jack and a piece of chain. I have found those to be the best tire machine I ever used. run that chain through the wheel and hook it over the jack lift, jack it up and let the base of the jack push the tire down on the rim. Works on the tractor or tire/wheel laying flat.
Big Jim
05-25-2004 06:00:12
I bought one recently from Shoup Manufacturing. Used it to change a front tire on my front wheel assist tractor-size 14.9-24. It worked really slick. I haven't tried it yet on rear 38" tires, but I see no reason why it wouldn't work well on these also.
Dan in Wisconsin
05-25-2004 05:17:40
Not familiar with that item but bought a handy little gizmo from Gemplers a few years back called the "Bead Buster". It takes the "bull work" out of breaking down the tractor rears, especially if they've been "welded" on by years of exposure to the elements. If that Bead-Cheata works as well as the Bead Buster it will be worth the money assuming you'll use it more than once. It was expensive but then so are visits to the chiropractor.
Dusty
05-24-2004 19:10:08
Lay it down and drive on tire as close to wheel as possible, sometimes I put a board on tire first.
Dusty
rustyfarmall
05-25-2004 04:45:39
 Re: Re: Tire Tools in reply to Dusty, 05-24-2004 19:10:08
That is rather tough to do if the tire is a rear tractor tire, and still on the tractor.
Chris Brown
05-25-2004 08:22:39
 Re: Re: Re: Tire Tools in reply to rustyfarmall, 05-25-2004 04:45:39
I have used another tractor and pushed the drawbar against a board on the bead of the tire I am working on.Crude but it works. I have used the handyman jack trick also,
