Tool Talk Discussion Forum
any drywall tapers
Michael
05-23-2004 18:22:48
I am getting set up for taping my garage which has a 11 foot ceiling. will 18-30 inch stilts work for the ceiling I am 5'8"? Im don't think they will. Do they make them any taller. What should I do use scaffles, I sure dont want to drag them all around.
thanks
bill b va
05-25-2004 09:53:39
 Re: any drywall tapers in reply to Michael, 05-23-2004 18:22:48
on my 12x24 attached garage i used 2 step ladders. placed the ladders against the wall, walk up side out. laid 2 landscape timbers on the appropiate steps then laid 3/4 x 12 in plywood on the timbers .... "C" clamped a 2x4 on one side about chest high to the ladders as a guard rail to keep me from falling off. was able to tape wall to wall on the ceiling .
Dusty
05-24-2004 19:36:10
Try for a Baker scaffle.
Bus Driver
05-24-2004 17:56:39
Just today a fellow finished taping for me. Best I have ever seen. He is 5' 2" tall, my garage ceiling is 9' 3". He does use stilts, but only 30" maxiumum. So I built a wooden scaffold he could drag around on the concrete floor. End frames 43 1/2" high, 62" wide. 2 x4's with plank gussets nailed and glued. 3 walkboards 2" x 12" x 12'. Ceiling about 2" over his head, he has short arms also.
Slowpoke
05-24-2004 00:45:42
No, they are too short. 5'8"=68"+30"=98". The ceiling is 132", almost 3' above your head. You need to get up at least 4'-4 1/2'.
rod
05-23-2004 20:31:31
You can usually rent one set of scaffolds with wheels, easy to roll around.
ZK(WA)
05-24-2004 12:45:40
 Re: Re: any drywall tapers in reply to rod, 05-23-2004 20:31:31
A scaffold is easier on your neck, back and legs than the stilts would be. And I think alot faster, in the long run.
Michael
05-24-2004 14:32:49
 Re: Re: Re: any drywall tapers in reply to ZK(WA), 05-24-2004 12:45:40
Thanks, I think that I will look into renting a set with wheels. My brother-in-law has scafles for ladder but at about 16 inch wide. it doesnt sound like fun.
