Tool Talk Discussion Forum
HELP!- problem with homelite weedeater
gary
05-21-2004 11:30:23
Please help- I have a '98 homelite 2.5cc gas weedeater-starts and runs, however will only achieve about 50% power-further gas will only bog engine down. I see no adjustment on motor eecptingto idle screw. Any suggestions would be appreciated.
Gary
JTEX
05-21-2004 12:04:30
 Re: HELP!- problem with homelite weedeater in reply to gary, 05-21-2004 11:30:23
Gary, Take the muffler off and apart and clean the screen in the muffler of just throw it away. Had the same problem on mine and it fixed it.The screen gets build-up on it.
gary
05-21-2004 13:02:24
 Re: Re: HELP!- problem with homelite weedeater in reply to JTEX, 05-21-2004 12:04:30
You're a miracle worker! Already repaired! As you suggested accurately-the muffler screen was indeed fully clogged. After removal-runs like a champ.
I really appreciate your help-have a wonderful weekend.
Gary
BillW
05-21-2004 22:08:37
 Re: Re: Re: HELP!- problem with homelite weedeater in reply to gary, 05-21-2004 13:02:24
Gary
The fact that the spark arrestor was clogged is a sign that you are mixing your fuel a little 'rich' and/or you are running your machine a little too slow.
That carbon will continue to build up and can damage your piston/cylinder in time.
JP
05-22-2004 09:17:47
 Re: Re: Re: Re: HELP!- problem with homelite weede in reply to BillW, 05-21-2004 22:08:37
One other thing that will cause this problem is not using 2 cycle engine oil design for air cooled engines. Outboard motor oil for the most part is a high ash engine oil, air cooled engine use a no/low ash engine oil.
Jumptrap
05-24-2004 16:20:05
 Re: Re: Re: Re: Re: HELP!- problem with homelite w in reply to JP, 05-22-2004 09:17:47
Jury is well out for concerning the use of 'outboard' 2 cycle oil. From where I am standing, I can't fault it in 25+ years of use in everything I have....chainsaws, outboards, Lawnboy and trimmers. Never had the first problem..ever. My lawnboy is 15+ years old and runs as new. My Stihl 028 was bought in 1981 and has cut tons of firewood. My outboard is a 1951 Goodyear 5 horse, the weedeater is a Homelite el cheapo and running great after 8 years. I buy any national brand of 2 cycle oil and mix it 32-1.....put it in everything.
