Tool Talk Discussion Forum
Telephone line tests
Slowpoke
05-20-2004 00:19:06
I have received an email that there is a possible telephone scam in which an "AT&T technician" calls your home number and asks you to press 90# and hang up, for some kind of line test. This is supposed to give them a way to make long distance calls and charge it to your phone. Said to be coming from jails and prisons, but where I live, prisoners can only call collect. I don't use AT&T, but I would not comply with any requests to help with "line tests".
thurlow
05-20-2004 15:12:59
 Re: Telephone line tests in reply to Slowpoke, 05-20-2004 00:19:06
When I was a kid, it was considered great fun to call an elderly person, identify yourself as an employee of the phone company and tell them you were conducting a test of the lines; they were asked to hold the phone away from their ear and listen/feel for a puff of air through the lines; they never failed to comply. Of course this was 45-50 years ago and it was a "simpler" time.....we were easily amused.
Ben in KY
05-20-2004 09:40:16
These types of scams are for the most part very real. I have been involved in the Telco business since 1973 and these types of scams have been around since then.
KX
05-20-2004 08:11:52
There was a scam that went around a few years ago where they would call into a business PBX (private branch exchange) and ask any one they could get on the phone to TRANSFER them to extension 900. They were betting on the transfer to go through, the 9 to access an outside line (typical protocol) and the 00 to get them a international operator (more typical protocol). They then had a open line to make any international call that would be billed to the business owning the PBX. This probably worked a few times, then a warning of this was published and it quickly faded. As a telecom engineer myself, I cannot see how dialing 90# from your single line at home would allow any access for them to redial unless your specific LEC has some sort of feature on your line where you can trasnfer incoming calls to another number or access another outgoing line from their switch. But the bottom line is, AT&T, or your local LEC probably isn't going to call you to help test their lines so, assume anything of this nature is suspicious and don't participate. Ask them to send a tech to your house to do the test calls, this will stop it if it is a scam. But remember, DON'T give any personal info to anyone over the phone, if it is the phone company, they already know your physical address.
Old Fart
05-20-2004 07:35:41
Check out www.snopes.com regarding this. No problem for the average person.
Urban ledgen?
05-20-2004 07:06:16
Sounds to me like another of these urban ledgen things. Some pople aren't happy unless they are passing on bits of wisdom.
Jerry B
05-20-2004 06:12:53
And they say prisoners don't have access to the outside world and cannot control their crime rings from behind bars.
What they hell are they doing with phones in there in the first place. These people in charge of these prisons must have a real bad rectal-cranial inversion going on. These convicts are there for a reason and it isn't because they played by the rules.
Rant mode off.
JDK
05-24-2004 08:52:11
 Re: Re: Telephone line tests in reply to Jerry B, 05-20-2004 06:12:53
Jail and Prison inmates cannot,by law,be held "incommunicado".The most common set-up is a "collect only" phone provided by phone co,where person recieving call must pay for it,even local calls.Unfortunately some inmates are technologically adept and have nothing to do but figure out ways to beat the system.Local jail had problem with a girlfriend working at hospital switchboard accepting,then routing her inmate sweety to an open line also one Atty relaying inmate calls to other numbers.Problem was resolved thru technology for the present.
