Tool Talk Discussion Forum
Sears Craftsman Shredder Chipper
moonlite
05-19-2004 20:04:19
I found a new Craftsman shredder and the motor pulley is missing. The machine is made by Troy and has a 10 hp Tecumseh engine with a 1" shaft and a "B" V belt. Just wonder what the diameter of the pulley should be or the RPM of the machine.
Slowpoke
05-21-2004 00:16:39
 Re: Sears Craftsman Shredder Chipper in reply to moonlite, 05-19-2004 20:04:19
Do you have the V belt? Set the engine where it was when operating. There should be some marks from the bolts. Put the belt on the existing pulley and you may be able to get the missing pulley size. There will only be three possible sizes, I think. The right one, one 1/2" larger, and one a 1/2" smaller. Otherwise, go to a Sears repair/parts depot or maybe the 'net and see if the parts list gives dimentions for the pulley. Or try Troy-Built.
It wouldn't hurt to have the operators manual, either.
jake
05-21-2004 08:41:16
 Re: Re: Sears Craftsman Shredder Chipper in reply to Slowpoke, 05-21-2004 00:16:39
Go to sears.com, under repair parts enter the model # and the blowup of parts is shown as is the price, saves messing around trying to make do.
Slowpoke
05-23-2004 22:49:26
 Re: Re: Re: Sears Craftsman Shredder Chipper in reply to jake, 05-21-2004 08:41:16
Jake, I wasn't sure that Sears had parts lists on line. That's good to know, but usually the machinery I get is too old to have any parts available. Maybe Moonlite will fine his pulley size for the chipper.
