Tool Talk Discussion Forum
Cut-off saw
Jim-IL
05-19-2004 14:56:55
I have a power miter box that I no longer use for wood cutting and was wondering if there is any reason to not use a cutoff wheel for metal in it? What sizes do these come in? what thickness? The saw has a 10" blade now.
sjh
05-21-2004 15:30:29
 Re: Cut-off saw in reply to Jim-IL, 05-19-2004 14:56:55
It can be done. You can get 5/8 arber cut off blades. Just make sure the blade is rated for the RPM of the saw.
Ben
05-20-2004 04:54:21
Jim: No can do , Your miter box RPM is too fast to put a cut off wheel on it. You will blow the cut off wheel up and cause damage to yourself or some one else, also the cut off wheel has a 1 in. arbor and your miter box is 5/8. The tool you have is mabe specificlly for cutting wood, please do not attempt to do this. You can buy a cut off saw for a reasonable price,look around. Good luck
