Tractor Repair Help
Daniel Machado
09-27-2000 10:04:10
I aquired a McCormick-Deering Tractor that runs and moves but it needs some major help. Under the sit in the casting is 01/10/35 & 2350-DA the date & model number; I think? On the block are the numbers 2396-D & 10 28 0. Any information on locating a manual and/or any technical support on this tractor would be great.
Thanks for any information on this!
F14
09-27-2000 16:17:16
 Re: Tractor Repair Help in reply to Daniel Machado, 09-27-2000 10:04:10
The 2350-DA is a part number. The date is probably a good one, but McCormick-Deering made quite a few models of tractors in 1935, F12-20-30, Industrials, W-series and 10-20/15-30 types.
A picture, or good physical description would help. Is it wide or narrow front? If it's a narrow front, it's most likely an F-series. If it has straight rear axles, it's an F-12. If it has drop axles, it's a 20 or a 30, or possibly a Regular.
If it's a wide-front, it's either a W-series or a 10-20 or 15-30.
And the other fella is right, you'll tap into a more specific knowledge-base if you post on the Farmall board, link below.
Wayne Swenson
09-27-2000 15:25:46
Post this message to the Farmall-IHC forum and you will have better luck
Wayne Swenson
09-27-2000 15:25:55
