Tool Talk Discussion Forum
Torque wrench question
Larry
05-18-2004 18:20:28
Does adding an extension or universal to the torque wrench make the ft/lbs of torque less or more? or have no effect?
Thanks Larry
CRUSADER
05-23-2004 06:54:47
 Re: Torque wrench question in reply to Larry, 05-18-2004 18:20:28
After reading the responses, I thought I would add mine to the list. With an extension on the socket and torque wrench, there shouldn't be any change to the torque setting. When you add/put a crow's foot, universal,...etc. on then this changes the equation and in order to obtain the proper torque the calculations have to be done. Sorry I don't have the formula to add to this thread handy. When I was performing the maintenance more than just supervising, a bunch of us came up with a "cheat sheet" for all of our "off center" fasteners needing torqued and we just used it.
Don't really think that the use of a cheater pipe on a torque wrench would change the torque that was put on the bolt or nut. I am one of those people who's metabolism has not slowed down very much and am lacking the extra weight and strength needed sometimes. Many years ago when I was working in the garages, I remember grabbing on to a torque wrench with another person in order to get the lugs torqued on a combine, all terrain lift truck or rock buggy. I can also recall needing another hand to achieve the proper torque on a pivot pylon on an aircraft. (This was one of the torque requirements on the "cheat sheet")
later days mates.
EIL
05-19-2004 15:33:41
OK, just to add fuel to the fire. I will throw in my 2 cents. First off I never saw a torque wrench that needed a cheater pipe to achieve the desired amount of torque. 1/2" drive torque wrenches are about 2 to 2 1/2 feet long and go up to 250 ft/lbs, 180ft/lbs is easily achievable with one hand and some leaning into it. 3/4" drive torque wrenches go up to 600 foot pounds but are 4 to 5 feet long. Second, I was taught that anything added between the torque wrench and the socket will throw the reading off. Think of it this way, when you use an extension on an impact wrench, it reduces the hammer action and the impact works way better without an extension. Also, a u-joint will throw the reading off too. Now with torque wrench extensions, you have to do calculations to make up for the added length. Take this information as you want!!!!! !
Joe (Wa)
05-19-2004 20:05:28
 Re: Re: Torque wrench question in reply to EIL, 05-19-2004 15:33:41
I am not going to put your fire out but....
I have a dail type 1000 ft lb 3/4" drive torque wrench made by Consolidated Devices Inc. It is exactly 21" long. Comes in a wooden box with a 3 handle extensions, 12", 18" & 24", that can used separately or connected together.
Pipsqueek that I am, I can torque the piston nut on a hydraulic cylinder to 600 ft lbs w/o using all 3 extensions. I can't believe that there is a hydraulic shop that doesn't have a similar torque wrench.
As for torquing with a socket extension, as long as the torque is in a straight line it does not matter whether the extension is made out of carbon steel or wet noodles, the torque on the fastner is the same as the reading on the torque wrench. Torque in equals torque out.
Joe
DaveCA
05-19-2004 17:09:42
I agree with most of that and to quench the fire a bit. First let me say, don't try this at home kids. If were talking about socket extensions, the impact gun analogy doesn't hold water. Consider the effect of hitting your head with a small mallet. Then put a soft coil spring between your head and hit the other end of the spring. I'm not saying iy won't smart, but it won't transfer the whole effect of the mallet. That's what happens when a socket extension is used with an impact gun, it takes some of the shock out.
When you add a spring between your head and a 50 pound weight and place the weight on your head, you pretty much have the same load to bear as when placing the weight on your head without the spring. This could be compared to the torque wrench application because you are suppose to apply the torque slowly.
Oh, and best regards.
Joe (Wa)
05-19-2004 10:26:00
The only torque effect on the fastner is in using a crowsfoot as Van stated. The crowsfoot is parallel to and after the pivot point.
A cheater on the handle will have no effect on the fastner. The cheater is before the pivot point, leverage just requires less effort to get there.
A socket extension vertical to the fastner will not change torque even with "spring". Torque in equals torque out. The extension can twist until it breaks, the torque on the fastner is still that as read on the pivot point.
A universal can only affect torque if it becomes parallel to the fastner, see crowsfoot above.
Joe
txblu
05-19-2004 12:52:45
 Re: Re: Torque wrench question in reply to Joe (Wa), 05-19-2004 10:26:00
Just so I didn't mislead someone.
If you are talking about taking a regular torque wrench and sliding a pipe over the end (where you hand goes) "theoretically" I'll agree that you didn't change the torque applied to the fastner for the same dial reading.
What you changed was the amount of force you had to apply to the torque handle to obtain the desired fastner tension.
I have enjoyed this exchange as this is how we and those watching learn. And frankly, that is why I'm here, besides R&R from the grind of the city job.
Respectfully
Mark
txblu
05-19-2004 11:06:46
So, am I to assume that a cheater is between the torque drive on the wrench and the driven socket? i.e. one end is drive female and the other is drive male?
If so, there has to be a correction factor stamped on the cheater to add to the torque indicated on the wrench's dial as the wrench is measuring between the twisting moment of it's square drive and it's handle where your hand wrests and any cheater installed in the circuit (between the wrench and the fastner) is adding length which increases the torque on the fastner as compared to the dial reading. Granted, the wrench will read the torque applied at the interface of the cheater and the wrench, but that is not what the fastner sees.
Round 2.
txblu
Coloken
05-19-2004 11:23:48
 Re: Re: Re: Torque wrench question in reply to txblu, 05-19-2004 11:06:46
I would call such a thing a torque "ampifier" and yes, you would be correct in such a case. I have never seen one, but I think they do make them.To me a cheater is like a pipe you stick on the end of the wrench. Us farmers have used such for ages. A modern engineer might call your thing a cheater but to old farmers a cheater is a 4 foot pipe. :-)
txblu
05-19-2004 11:46:43
 Re: Re: Re: Re: Torque wrench question in reply to Coloken, 05-19-2004 11:23:48
That's exactly what I envisaged my man; course I'm a johnny come lately farmer. Just been at it 25 yrs and when I was getting my discs off the harrow , to put on a new set the other day, that is exactly what I used cause the 48" pipe wrench and my arm's muscle just didn't have enough TORQUE. Needed a 2:1 amplifier which worked nicely.
Mark
Joe (Wa)
05-19-2004 12:33:34
 Re: Re: Re: Re: Re: Torque wrench question in reply to txblu, 05-19-2004 11:46:43
Just to be nitpicky, a cheater refers to an extension prior to and measured at the pivot point of the torque wrench.
A torque "amplifier" or multiplier is between the pivot point of the torque wrench and the fastner. The torque reading is a fractional value of the force applied to the fastner. The torque wrench fractional reading can be fixed as in a geared multiplier or calculated as in the length of an extension that is parallel to the fastner.
If you have a bending beam torque wrench with a pivoting handle, all other things being equal, it will be accurate only when input force is applied at the handle.
Joe
Charles (in GA)
05-19-2004 20:10:43
 Re: Re: Re: Re: Re: Re: Torque wrench question in reply to Joe (Wa), 05-19-2004 12:33:34
At work I got into quite some discussion about torque wrenches, specifically the micrometer type/click type tool.
The discussion centered about the fact that I felt the outer housing of the tool was rigid and it really would not matter if you grasp it at the knurled handle or further in on the body of the tool. The effort you would exert would be more if you grasp it further in, but the fastner would see the same torque when it clicked. The click is "the click" right? This seems quite a logical assumption for the click type torque wrench but the discussion was with the man who calibrates our several hundred different torque wrenches. We took a good one, right off the rack and put it in the calibrater. Set the tool to pull at the center point of the knurled handle, the correct grasping point and it was absolutely accurate. Then we set the tester to pull on the body of the tool, further in from the knurled handle portion.
Now mind you, I am talking the micrometer type/click type tool, NOT a bending beam type, which I am well aware must be pulled on by the handle, using a floating one on a pivot pin.
Anyhow, the further in on the handle of the click type we pulled, the less accurate it was. Basically, it boiled down to the fact that in order to make the tool light in weight, the tube that makes up the tool has to be thin, so thin that it bends when torque is applied. This bending is taken into account in the design of the click type tools and if you pull anywhere other than where you are supposed to, the tool will not bend properly and the clicker will not be clicking at the correct, set torque. I would not have believed it except that I saw it on the tester myself.
Dial type torque wrenches, on the other hand are a rigid type tool and most larger ones, 3/4 drive and up, are designed to be used with extension handles or without, being completely rigid with the dial reading the turning of the square drive inside the tool, length doesn't affect it, nor does the point at which you grasp the handle.
Old bending beam type torque wrenches are the most accurate (according to the guy who calibrates our tools) but are the pickiest about being handled just so and grasp and pulled just so properly.
I had a brand new Utica 1/4 drive click type I had bought govt surplus and it was out of limits and also the errors were non-linear and thus could not be corrected, small pile of junk.
Charles
txblu
05-24-2004 05:49:30
 Re: Re: Re: Re: Re: Re: Re: Torque wrench question in reply to Charles (in GA), 05-19-2004 20:10:43
Well put.
I work where things have to be calibrated and usually they are pretty close. Nothing at home is calibrated so there is some concern. But I know that I am in the ball park of the required spec and the important thing on head bolts is that if in error, they are all in the same error, and therefore exerting equal force on the head. Sometimes, I just use an impact tool and use it as the wrench. Amazing how consistent the results are.
Mark
txblu
05-19-2004 09:05:58
Well you guys blew me away.
Torque is measured in Foot/Lbs among other things. That says I have a product of distance x resistance to overcome; don't care which is which or what.
The reference for distance is the handle at whatever length is is when designed, and the twisting torque (resistance) is the resistance of the object to be turned.
If I add the length of the cheater to the distance , the force applied may be the same, but the distance has increased, hence the length you added to the handle gives you a false reading by the ratio of the lengths.
Take 100 ft/lbs. I have an object resisting 100 lbs of force applied at a distance of 1'. The needle reads 100 ft/lbs.
If I move my 100 lbs of force out to 2 feet, I am now applying 200 ft/lbs of force to the object if the needle is still sitting at 100.
Take a bolt that won't budge. You get a wrench of some length (distance ft) and pull as hard as you can (force lbs). You put a cheater bar on the wrench exactly the same length as the original wrench. Length is now 2x what is was so force (in ft/lbs) is twice what it was. That's the force at your hand working on the object to be moved, not the force applied at the handle...that is half what you are applying.
The stuck bolt moves freely because you put twice the torque on it with the cheater.
Think about it. Better yet test it. Mathmatics doesn't lie; it is or it isn't.
txblu
bob
05-21-2004 18:10:36
 Re: Re: Torque wrench question in reply to txblu, 05-19-2004 09:05:58
you must remember the force being measured is between wrench and bolt not between handle and top side of wrench. the topic of handle being lighter would have some bearing but if a torque wrench doesn,t receive constant calibrating you are going to be off anyway. the end product is only as good as equipment doing it.
Coloken
05-19-2004 11:13:13
Sorry txblu, I think you may missunderstand the use of a cheater bar. Yes, it makes the pressure at your hand less but the reading/clicker or what ever "reads" the torque or "breaks" is just above the socket and is not effected. Example: 100 ft/lbs: with a 12 inch handle you would pull 100 lbs. With a 24 inch handle you would pull 50 lbs. Guage would still read 100...Or some other screwey metric thing.
txblu
05-19-2004 12:02:21
 Re: Re: Re: Torque wrench question in reply to Coloken, 05-19-2004 11:13:13
Ok. Your cheater bar is something foreign to me that not only gives you torque amplification, it also sends this amplified information to the indicator.
Otherwise the indicator would not know to move to 100 when it was only putting out 50. Since it's head was stressed at 50 and your hand was on the handle, it would say 50.
Now if you told me that the cheater was stamped "Multiply the dial reading by 2" then I would understand what you are saying. YOU mentally perform the 50 x 2 multiplication to get your 100 ft/lbs.
txblu
rhudson
05-19-2004 09:49:04
i think when the fellow says "extension" , he means socket drive extender not "cheater bar" a drive extension will not change torque since leverage is not changed. i can think of no reason a "cheater bar" would be used on a torque wrench. it would make the reading incorrect(on some types ),damagehe torque wrench. crows feet adapters reduce the lever effect of the torque wrench therefore the reading of the torque must be reduced by the formula that is included in the instructions with the wrench (that slip of paper you threw away when you opened the box) on another note: why is it that when i go back to correct my comments, i cannot insert a correction without typing over my existing comments?
txblu
05-19-2004 10:58:01
 Re: Re: Re: Torque wrench question in reply to rhudson, 05-19-2004 09:49:04
I hear you but that was not indicated. But I agree that an extension between the wrench and socket doesn't change things other than as mentioned in the orig post, steadying the wrench could introduce error.
On the question about deletion, there is an "Insert" key just to the right of the Backspace key. Push it once it toggles to overtype. Push again, it toggles to add.
Best,
Mark
rhudson. Thanks
05-19-2004 11:13:53
 Re: Re: Re: Re: Torque wrench question in reply to txblu, 05-19-2004 10:58:01
knew there had to be a way to prevent it.
txblu
05-19-2004 11:48:04
 Re: Re: Re: Re: Re: Torque wrench question in reply to rhudson. Thanks, 05-19-2004 11:13:53
Glad to help.
Van in AR
05-19-2004 07:13:53
A extension will not alter the torque applied. A long crowsfoot with the opening forward or backward will and there is a formula to calculate the setting on the wrench, however a short crowsfoot installed at a 90 to the handle will not alter the setting enough to worry about.
Van
Charles (in GA)
05-18-2004 18:45:04
A regular extension should not make any difference in torque, you are still turning the socket in direct line with the square drive. If the extension were "springy" like a torsion bar, it could, but a regular forged extension like a snap-on or craftsmen would not.
A long extension may cause you some problems as you tend to side load the extension and as a result you have to brace the extension or the rachet/torque wrench head with your hand or fixed object to keep it in line and square with the fastner as you apply torque, this could also cause errors in your readings.
A universal joint would if the joint were not perfectly straight. A universal will not transmit torque completely, some gets "lost" when it is at an angle. I would do anything I could to avoid a u-joint as you have no way to know what you are really putting to the fastner in the way of torque.
Use as few adapters, extensions, etc as you can possibly get away with.
Charles
MarkB
05-19-2004 07:36:31
 Re: Re: Torque wrench question in reply to Charles (in GA), 05-18-2004 18:45:04
Charles,
A springy extension won't reduce the torque transmitted through it any more than putting softer springs on your car will make it weigh less. It might make it trickier to get an accurate reading, but the torque still has to be transmitted through the extension because there's nowhere else for it to go.
The universal joint shouldn't significantly affect the torque reading as long as it's bent at a reasonable angle.
