Tool Talk Discussion Forum
Eastwood Vibratory Tumblers
Andy
05-17-2004 14:51:29
I'm looking at the vibratory tumblers in the Eastwood catalog for cleaning small parts. Are they worth $150+ for nuts and bolts? Would a rock polisher do the same thing?
Pete
05-17-2004 16:29:34
 Re: Eastwood Vibratory Tumblers in reply to Andy, 05-17-2004 14:51:29
Try www.grafs.com or www.midway-usa.com for tumblers that might work for you. They are used for tumbling rifle and pistol brass, should also work for nuts and bolts and they are much less than $150
jeff
05-18-2004 19:36:40
 Re: Re: Eastwood Vibratory Tumblers in reply to Pete, 05-17-2004 16:29:34
Sonds good as I also shoot and load my own. One of these units will work best if you remove ALL grease and as much rust as you can. Also go to a big gun show and pick up crushed walnut shell. The corn cob is only for fine pollish. DON'T get the bright idea to put sand in your machine cause the bowl will not like it. Brass with a little haze on it will clean up in about 1 hour.
Steel is a lot harder. Also the big machines are worth the cost cause size do matter! ALSO DON'T BOLT ONE OF THESE THINGS DOWN ! They do a heck of a dance when they run and it is a GOOD thing.
Look up DILLON on line. These folks sell some of the best reload stuff in the world with great service and price. They are at most every large gun show with great deals! check it out. Jeff
