Tool Talk Discussion Forum
Polishing level vials
Slowpoke
05-17-2004 01:49:11
I have a 5 window level with dual vials that was used in the masonary trades. The plastic covers on the vials are dull and very hard to see thru. I used plastic scratch remover and a soft cloth and lots of elbow grease on one. I've managed to get the cover pretty clear, but the view has a wavy appearance and is not the best. (I found one supplier for new vials at $6 each, but there are only 3 left.) Does anyone have advice on a better way to restore the plastic? Polishing wheel, material, compound, speeds?
IMKCMAC
05-22-2004 18:29:31
 Re: Polishing level vials in reply to Slowpoke, 05-17-2004 01:49:11
Slowpoke,
Try using plain ole toothpaste and water.But don't use anything except a cotton rag(old socks,tee shirt) of some sort.I have used this method several times with excellent results.
Mark Too
05-17-2004 17:02:31
I use this to clean the plastic lens on my instruments.
Cliff (VA)
05-17-2004 14:07:14
In the automotive industry Novus plastic polishes are used on scratched lenses. It comes in 3 grades (grits) and can work wonders. You will need all three (progressive) for heavy scratches.
Cliff
Coloken
05-17-2004 07:07:39
Same problen with cell phone when carried in shirt pocket too long.
John *.?-!.* cub owner
05-17-2004 06:53:06
I've used plexiglas cleaner (available at many auto parts stores) on plastic head light lenses, it may work for your problem.
Ernie
05-18-2004 20:11:02
 Re: Re: Polishing level vials in reply to John *.?-!.* cub owner, 05-17-2004 06:53:06
Try plain old "pledge" spray polish. I used it on all types of plastic from the windshild on my Goldwing to my eye glasses. It will fill shalow scratches and improve transparency
