Tool Talk Discussion Forum
Webster Compressor not compressing?
riesman20
05-16-2004 20:14:08
I have a webster that I rebuilt but it does not seem to compress much. It has a system above the cylinder with two little pieces of steel that suck air in and one that pushs air to the tank. I can hold the outlet with my finger and it never builds any pressure. I have sealed the maze in the head that allows air to go in and out as I thought it was short circuiting but it did not help. Any suggestions. Roger any ideas?
Roger
05-16-2004 21:46:55
 Re: Webster Compressor not compressing? in reply to riesman20, 05-16-2004 20:14:08
You might have the gasket that fits between the valve plate and the cylinder head plate put in wrong way around. If I remember correctly, there is a small strip of gasket separating the intake and exhaust sides of the head. If this gasket is in the wrong way, the two chambers are linked, and no compression will take place. Also, the reeds might be sitting too far off their seats to seal properly. If the reeds have been fouled for a long time, like from paint overspray buildup, they tend to take a "set" and never quite sit flat anymore, even after they are cleaned. If the pump is turning too slow, this might also prevent the reeds from seating, as they need some pressure to seat properly as well. BTW, the "maze" should have a filter pad behind it, and it will most definitely not compress if the intake has been plugged.
riesman20
05-17-2004 08:00:31
 Re: Re: Webster Compressor not compressing? in reply to Roger, 05-16-2004 21:46:55
There was no gasket on the very top between the maze" and the reed's. I made one that went around the outside and than I put silicon around the maze to seat it. It still did not work, should I make a gasket for that?. There is no filter and I replaced one of the intake reed's but it is steel on steel so how much of a seat can you expect anyways??
Roger
05-17-2004 15:04:53
 Re: Re: Re: Webster Compressor not compressing? in reply to riesman20, 05-17-2004 08:00:31
Ther are two separate gaskets in a Model 21 head. One seals the valve plate to the cylinder and is a simple gasket with a hole to clear the piston crown. There then has to be another gasket between the upper part of the head and the top of the valve plate. This gasket must provide a means of segregating the intake side from the discharge side, otherwise, any air taken in by the piston will be discharged right back into the intake side as soon as there is any backpressure. Making a gasket that goes just arond the periphery of the top of the cylinder head and valve plate will not accomplish this. Take off the top of the cylinder head and look at it closely, there should be a rib going across the middle somewhere, or most likely, along a diagonal. There must be a strip of gasket crushed between this rib and the top of the valve plate to form a seal betwen the intake and discharge sides. I would be suspicious that the replacement reed is also not seating. It should be a steel reed sitting on an aluminum valve plate. If this plate is steel, it is probably homebrew.
riesman20
05-17-2004 20:01:47
 Re: Re: Re: Re: Webster Compressor not compressing in reply to Roger, 05-17-2004 15:04:53
Roger, if I read you right I need a gasket between the intake and the discharge? does it have to line up with the maze?when taking it apart I see that there is a part that the discharge reed empties into but I will not open all of the way as a portion of the maze cuts across it. is this the spot that needs to be sealed? also there is a tiny gash in the aluminum part under the intake reed, is that small amount enough to cause shortcircuiting?
Roger
05-17-2004 20:20:13
 Re: Re: Re: Re: Re: Webster Compressor not compres in reply to riesman20, 05-17-2004 20:01:47
You need a line of gasket material between the intake and discharge sides of the head. Otherwise, the compressed air will go back towards the intake. If there is something interfering witht the operation of the discharge reed, then I would suspect that the valve plate and cylinder head are not properly oriented with one another. Neither the intake nor the discharge port should be on the same side as the flywheel.
riesman20
05-18-2004 07:53:50
 Re: Re: Re: Re: Re: Re: Webster Compressor not com in reply to Roger, 05-17-2004 20:20:13
I have them opposite of each other. Still unsure "exactly" where the gasket should be, but I will insure that there is a barrier between the two.
riesman20
05-18-2004 19:49:05
 Re: Re: Re: Re: Re: Re: Re: Webster Compressor not in reply to riesman20, 05-18-2004 07:53:50
Roger. Can I send you an email with the picture of the valve plate and head. I took all of the reed valves off and the one for the discharge lines up almost right on a barrier of the "maze" as I call it. Is that normal? the spot directly behind it is a blank area.
Roger
05-18-2004 22:46:02
 Re: Re: Re: Re: Re: Re: Re: Re: Webster Compressor in reply to riesman20, 05-18-2004 19:49:05
The gasket for the valve plate is a perfect square, with four bolt holes for the studs, a small square cutout for the intake reeds and one slightly longer, narrower cutout, that gets wider at the end, for the discharge reed.
Often, discharge reeds will have a protrusion or rib over them to prevent them from travelling excessively.
riesman20
05-21-2004 06:52:02
 Re: Re: Re: Re: Re: Re: Re: Re: Re: Webster Compre in reply to Roger, 05-18-2004 22:46:02
Thanks Roger I wouldn't have gotter pumping without you.
