Tool Talk Discussion Forum
Jacobs chuck and arbor
JC
05-15-2004 10:42:23
I bought a used Jacobs 1/2" drill press chuck to replace the chinese piece of crap in my Craftsman drill press. It came with a 3MT arbor that I need to remove as my drill press accepts a 2MT arbor. Trouble is, it will not budge from the chuck. I have tried open the jaws all the way and placing it in my 12 ton press trying to drive the arbor out the back with a piece of round stock inserted through the open jaws. Also tried air hammer. No go! What am I doing wrong here? ANy suggestions? Thanks
Davis In SC
05-15-2004 11:49:44
 Re: Jacobs chuck and arbor in reply to JC, 05-15-2004 10:42:23
Jacobs makes a set of wedges to remove arbors from chucks. I think they are sold by Travers Tool, J&L Ind. Supply, MSC, etc
JC
05-15-2004 12:06:21
 Re: Re: Jacobs chuck and arbor in reply to Davis In SC, 05-15-2004 11:49:44
Got iT! Had to hit it harder than a pin punch that size should ever be hit. But I got it! I think those wedges are for removing chucks from spindles rather than from arbors. Thanks!
Charles (in GA)
05-16-2004 19:20:27
 Re: Re: Re: Jacobs chuck and arbor in reply to JC, 05-15-2004 12:06:21
JC, are you saying you were able to separate the chuck and arbor?
I have a Jacobs 18N chuck on a JT4/MT3 arbor (bought it used already assembled) I've done about everything to it and could not separate it, didn't want to destroy it so I finally gave up and put it in the drill press after washing it out with mineral sprits and soaking in synthetic oil.
It has a tiny hole inside, would not take more than about a 1/8 punch.
I wanted to separate it because my 3N1 mill/drill/lathe unit has a MT3 tailstock but must have an arbor without the flat on the top (such as a live center has), and I wanted to be able to swap the chuck onto the lathe tailstock ocassionally.
I bought it to replace the Taiwan made, way too small, chuck on my Dayton/Grainger 20 inch drill press.
Wedges remove a chuck from a drill press with a JT machined on the bottom of the Quill (cheap drill presses), or as a way of separating the 1) chuck from the arbor, or 2) arbor/chuck assembly from the quill, which ever comes off first when forced with the wedges. and drill drifts remove arbors from quills with slots.
Any ideas or should I give up and buy another 18N chuck, not already mounted on an arbor?
Charles
Davis In SC
05-15-2004 17:00:49
JC, the item to remove the arbor from the spindle is called a "Drift", & they are made in sizes to fit #1,2, 3 Etc. Morse tapers. The wedges I referred to are thin tapered tools that come in pairs to be used to remove the arbor from the chuck. Regards, Davis
MAC,IL
05-15-2004 11:03:09
try the following link, maybe it will help.
http://www.beautifuliron.com/mttaper.htm
JC
05-15-2004 11:33:48
 Re: Re: Jacobs chuck and arbor in reply to MAC,IL, 05-15-2004 11:03:09
That is a nice site. He describes the methods I have been using to remove. Don't know why it is so stubborn.
