Tool Talk Discussion Forum
Help needed to repair gear socket
David
05-14-2004 06:28:28
The socket (the hole) where the shaft of my starter gear goes into the aluminum engine case of my 4 wheeler is wallowed out causing the gear to wabble just a little. How can I repair it? I have thought of using epoxy or JB weld. Will that work? Surely there has to be a way to repair it. Any suggestions will be greatly appreciated.
RZ(WA)
05-14-2004 20:20:18
 Re: Help needed to repair gear socket in reply to David, 05-14-2004 06:28:28
JB Weld, although great all around stuff, may not hold up for very long. Try getting in touch with a local Devcon dealer. Some of their goop seems a bit on the pricey side, but it works and stays put a long time.
