Tool Talk Discussion Forum
Plug-in battery post connectors
Big Bob
05-13-2004 13:05:02
I've heard that you can buy battery wires where the connector stays bolted to the battery post and you unplug the wire (male-female style) from the connector when not in use to avoid damage and fire hazard from shorted out electrical wires. Anybody know of such a thing or where you can buy them? Thanks
Chip
05-21-2004 12:19:32
 Re: Plug-in battery post connectors in reply to Big Bob, 05-13-2004 13:05:02
Just lokked at shoup's for something,saw a terminal disconnect.
WD-9
05-18-2004 20:19:33
I always aim for the fewest connections (failure points) possible. Perhaps instead of adding possible points of failure/corrosion you could rearrange your batteries so it would be easier to disconnect the positive terminal (the corroding one) with a simple open-end wrench.
Just my $0.02
viagra
04-07-2006 14:31:30
 viagra in reply to viagra, 05-18-2004 20:19:33
viagra http://freewebhouse.com/viagra/viagra.html viagra http://freewebhouse.com/viagra/viagra.html
dw
05-14-2004 08:17:37
At one time Tractor Supply handled the green knob type. I think they were around $5.00. I don't know if they still sell them. They work good. I have one on a B JD. It keeps the battery from discharging, when not using the tractor.
T_Bone
05-14-2004 07:19:57
Hi Bob,
The only other disconnect that would be rated for the amperage would be a "jones" plug for golf cart chargers.
The kinfe/blade type would cost less, maybe from Camping World, JC Whitney.
You might also look at boating supplies as I think they use a automatic disconnect (spendy).
T_Bone
Dusty
05-14-2004 05:32:42
Recreation vehicle supply places (dealiers) have battery disconnects that are a blade type that mount on the post.
Dusty
Chip
05-13-2004 15:41:27
There are disconnects (switches),check a truck & heavy equip supplier,industrial battery shop,forklift shop,or get welding cable m/fm extension connections.I don't know whats near you.
Bill
05-13-2004 14:43:29
Closest thing I have seen are the Green Knob disconnects. All you do is unscrew the knob about a turn or two. Easiest place to find? E-Bay, $4+ shipping. I'll attach a link. These things are ALWAYS offered there @ $4....
You'll have to do cut & paste....
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1&item=2478595708&category=33574
