Tool Talk Discussion Forum
Weed Eater / help
Dewey
05-13-2004 07:07:10
Ive got a Ryobi Weed eater, starts good runs fine, but when you pull the trigger it boogs down, but if you pull it real slow it will reve and run fine, why dose it bog down when pulled fast.
goddago
06-14-2004 18:02:17
 Re: Weed Eater / help in reply to Dewey, 05-13-2004 07:07:10
My Ryobi 725r is showing same symptoms, but muffler seems to be sealed.Any help anyone?
Tom McGrath
06-08-2004 08:51:13
Line does not advance. I am able to wind it like the direction instuct. What can I do?
Crem
05-14-2004 09:01:28
Thanks everybody for the suggestions of a clogged muffler. I just read this thread last evening and found a clogged muffler on my weed whip. I cleaned it and now it has pep again. It was almost completely clogged.
Paul
05-14-2004 12:55:53
 Re: Re: Weed Eater / help in reply to Crem, 05-14-2004 09:01:28
i was just browsing this forum and read this thread. my 20 year old weedeater has been doing the same thing for years. i think i'll clean out the muffler this weekend.
JP
05-13-2004 16:48:47
Adjust the screw closest to the air filter, turn it out 1/4-1/2 turn, turn the other out 1/8-1/4 turn. then you might have to turn back in just a little to lean out so not as rich. Good point check muffler screen, or the take off muffler and check exhaust port.
Vern-MI
05-13-2004 13:29:38
Turn the Low speed fuel adjustment counterclockwise just a smidgen to enrich the low speed mix. Keep trying to rev it up while adjusting the mix.
Dewey
05-13-2004 13:12:30
Thanks for helpfull the tips, also this is not in high weeds, it dose it while not cutting grass, so a 454 chevy is not needed.
MAC,IL
05-13-2004 09:45:02
Pull the muffler and see if it has one of those spark arrestor screens in it. You can clean them or I just toss them. restriction there will cause same symptoms. A carb kit may be in order here also, not that expensive. Some of these rascals have a very touchy adjustment also. Use correct gas mix and be consistant with the mixture.
gspig
05-13-2004 09:19:13
Been fighting my ryobi since last spring. Your bogging down because you are either flooding or starving the engine of fuel. If I were you, I would get a rebuild kit for the carb and clean the carb housing well. Next, I would check the cylinder jug. I found my piston was scored badly, I thought I had ordered a cylinder assembly/w piston; it was just the cylinder. Still that seemed to improve performance. Big thing to remember: fresh gas, proper oil mix.
KX
05-13-2004 07:20:43
Dewey, Getting that weed eater head to spin is just too much load for those tiny engines. This aint your 454 chevy that you can slam to the floor and burn rubber. The weedeater engine relies on momentum to keep the head turning, that is why in high weeds grass it can be slowed/stopped if over loaded. Patience with those little engines is required.
J-TEX
05-13-2004 10:09:02
 Re: Re: Weed Eater / help in reply to KX, 05-13-2004 07:20:43
I would bet on the muffler screen, had the same problem on a homelite took out the screen and has been running fine since.
j-tex
John *.?-!.* cub owner
05-13-2004 19:07:00
 Re: Re: Re: Weed Eater / help in reply to J-TEX, 05-13-2004 10:09:02
I found mine ran much better when I cleaned the mud dauber's nest out of the muffler!
