Tool Talk Discussion Forum
Can't remove engine pulley, because shaft turns.
Jim
05-12-2004 05:59:16
I am baffled as to how remove the engine pulley from my MTD 16.5 HP riding mower, when the engine shart simply turns when I pull the wrench to remove the bolt that holds the pulley on? Any advice will be greatly appreciated.
Thanks,
Jim
Jim
05-12-2004 08:14:52
 Re: Can't remove engine pulley, because shaft turn in reply to Jim, 05-12-2004 05:59:16
Thank you both very much! I will give the air ratchet a try first. Although the rope idea is ingenious, and if it worked, I would not have to by an air ratchet. Hmmm... Great ideas. Thanks!
Jim
Alan Y.
05-12-2004 12:03:13
 Re: Re: Can't remove engine pulley, because shaft in reply to Jim, 05-12-2004 08:14:52
The rope will work. However, if you don't already have an air ratchet, don't buy one just for this. An air ratchet is NOT an impact tool and will not give you any more torque than you can provide by hand.
Bob
05-12-2004 06:08:50
As the other poster says, an impact wrench works great! The other way is to stuff a length of cotton clothesline rope into the cylinder, through the spark plug hole, being carefull to leave a "tale" stick out for removal later.
The piston comes up against the wad of rope, and jams, holding hte crankshft.
Bernie in MA
05-12-2004 06:03:48
An impact wrench will usually do it.
