Hi Slowpoke, Yes you can Mig weld copper. The next question is it cost effective for a small job? No! You would need CU filler wire, Steel lined contact tip, brass cup, using AR cover gas. The filler metal always needs to be a compatible metal to the base metal being welded, SS to SS, CU to CU, Pb To Pb, etc no matter what welding process is used. The welding process usually is not the problem although it would be on this project because of the size of the parts being joined, MIg would be a poor choice if not impossible to the average welder. Tig would be a excellant process choice here. Great heat control with easy starting on small parts. AR cover gas with a CU filler rod. Oxy/Acet would be another excellant process. You will again need to use a CU filler rod with a 00 size brazing tip with a low flame temp. For practice use a couple pieces of No.18 awg CU wire (HVAC t-stat wire) cleaned with emery paper then layed side by side then use a piece of 22ga CU (telephone wire or a strand of CU wire) cleaned with emery paper for filler rod use. When you can weld together the 18ga wires without burn thru then your ready to tackle your job at hand. Lower heat is best and your finished bead should look just like any other weld, nice and smooth. Keep the torch heat faced away from the armature windings. Another idea might be to make some CU rivets out of CU wire, drill two holes, insert the wire rivets, then peen the rivets, then solder with 50/50 or 60/40 for good electrical contact. T_Bone
