Tool Talk Discussion Forum
Which Pressure Washer to buy???
Kerry Brunner
05-10-2004 19:25:45
I'm interested in buying a pressure washer, but really don't know enough about them to decide which would be the best buy. I think that I'm going to defintely go with a gas-powered version. Which pumps have the best reputation? Are the ones at Home Depot for around $600 or so worth the $$$ or what about the one at Northern Tool for about $500???
What's the longest lasting and most reliable washer for the money today??
Tim FL
05-12-2004 01:03:16
 Re: Which Pressure Washer to buy??? in reply to Kerry Brunner, 05-10-2004 19:25:45
Good advise from Gene. I like mine with a Honda motor and a Comet pump. One thing I have found is that some of the cheaper units do not use standard pressure washer fittings on the hoses. This makes it difficult to add accessories later. Purchased mine from a local shop that specializes in pressure washers, they are good for service later.
Gene Davis (Ga.)
05-11-2004 19:37:04
When you buy a pressure washer the most importnt thing is not always the price, or advertised pressure. You need to be aware that lots of them put out pressure for a short time, but it takes a good big one to produce a high gallon per minute count that is necessary for the fast heavy duty cleaning that you desire. I have a Northern Tool 10 hp gas unit rated at 3,000 psi and 4 gpm and it has served well. Look at the different brands and types then buy one that is at least 50% bigger than you want and in 30 days it won't be big enough for something you want to clean.
buickanddeere
05-11-2004 04:53:55
Something with a brass three piston ceramic pump that will take 140F tap water. Cold water washing is slow and inefficient. Cat brand is the very best pump. At least 2000psi or leave it in the store.
