Tool Talk Discussion Forum
SandBlast Nozzles.....
Mike
05-10-2004 19:22:24
I need a source to buy a replacement nozzle for a siphon-feed sandblaster. 1/2"OD, 1/8"ID. Would like a carbide nozzle. Can anyone help ??
Earl S.
05-11-2004 20:08:10
 Re: SandBlast Nozzles..... in reply to Mike , 05-10-2004 19:22:24
We use this source for all our Automotive Shop needs. www.goodson.com 1-800-533-8010.Ask for glass bead ceramic or carbide nozzle. Look up there web: than order .Earl In Illinois
Mike
05-11-2004 19:13:28
Thanks all, I made a tip out of carbide today at work. Should be interesting to see how long it will last. Mike
wdTom
05-11-2004 17:37:33
If you aren't going to use it too much you can just drill a hole through a piece of steel rod. It will last for a surprising long time. And is cheep and easy.
Steve-Maine
05-11-2004 02:23:35
You might try www.mcmaster.com I placed an order for sandblast nozzles on a Thurs evening on line and UPS delivered Monday morning. They handle all types of sandblaster parts. Good Luck
Slowpoke
05-10-2004 21:36:07
May be called Truman's or TIP, somewhere in Ohio. Try www.yellowpages.com for anywhere.
