Tool Talk Discussion Forum
pneumatic grease gun
Rick
05-08-2004 18:37:10
I was thinking of getting a pneumatic grease gun. Anyone have any experience and brand recommendations?
Fred OH
05-13-2004 07:41:10
 Re: pneumatic grease gun in reply to Rick, 05-08-2004 18:37:10
There is a tool made that you fill with oil and put it over the top of stubborn grease fittings and smack with a hammer and it forces grease through fittings where the grease has dried up inside creating a blocked passage. The only problem I've seen with mine is you might have to take out an angular fitting and install a straight one so you can hit it with a hammer without breaking it off. Now you know the rest of the story. Fred OH
Rod M1
05-11-2004 11:37:36
Is there a fitting available that will fit on to a grease fitting sow tight it wont leak even on hard to lube fitting
Jerry A.
05-10-2004 09:58:23
Consider getting the continuous flow type...as long as you hold down the trigger, grease will flow. The other cheapy ones only pump a small amount each time you pull the trigger; that gets old ( I have both types). I bought a continous flow type Craftsman at Sears that works well. It was about $50. Lincoln makes one also. It can be purchased from Harbor Freight for about the same amount.
Not much help, but
05-09-2004 21:55:17
It's a lot easier to use than trying to hold a flex hose on an old fitting and pumping with one hand. Just push on and go.
RayP(MI)
05-09-2004 18:41:08
I have a cartridge type gun, believe it was marketed under the Coleman brand name. Works OK for simple greasing, but cannot generate enough pressure to force grease into tough places. I get our the old hand operated guns, for that, infact, hardly ever use air powered unit.
Ray,IN
05-08-2004 21:44:21
I have two, one is for a 30gallon drum and the other a 5 gallon pail. They are really nice for lubing equipment at the barn. I carry a battery powered gun in the fields, the plastic case holds the gun and 2 extra tubes. I just strap the case onto the tractor and run.
Jon H
05-08-2004 19:34:51
I use a Lincoln pneumatic grease gun which has been more reliable than the cheapy types. If I was to buy another I would try a Plues(sp?) brand gun. They have the pump mounted on the grease tube at 90 degrees angle compared to most others with the pump mounted at a 45 degree angle. The 90 degree pump mount has a much shorter grease passage from tube to pump,this makes cold grease flow into the pump a lot easier.
