Tool Talk Discussion Forum
weilding manafold
Vince
05-05-2004 18:13:31
what rod would you use to weild a manafold useing a AC weilder?
Kendall
05-06-2004 13:03:53
 Re: weilding manafold in reply to Vince, 05-05-2004 18:13:31
you'd be happier with a new manifold but if you got the skill and time, here is a good article on welding cast iron.
Let George do it
05-06-2004 06:35:17
No joke. Let George do it. That man is good. Go to his web site. kpierce
Kelvin
05-06-2004 18:24:47
 Re: Re: weilding manafold in reply to Let George do it, 05-06-2004 06:35:17
You need to go look at that manifold George fixed: I put it on and heard the tractor run 2 weeks ago.
george md
05-06-2004 20:18:06
 Re: Re: Re: weilding manafold in reply to Kelvin, 05-06-2004 18:24:47
Kelvin,
Glad you have it together , last I knew you were looking for a carb kit , you must have found one . Did the ports line up and how does it sound ? george
george md
05-06-2004 16:05:28
Thanks Ken
george
buickanddeere
05-06-2004 05:51:20
If a new manifold can be purchased forget about welding an old thin corroded piece.
MAC,IL
05-06-2004 06:32:03
 Re: Re: weilding manafold in reply to buickanddeere, 05-06-2004 05:51:20
I'll go along with replacement. If you take the time to R&R for welding. Chances are it will give you a problem later on, just when you least expect it. Lot of those welds just wont hold up.
george md
05-07-2004 17:53:45
 Re: Re: Re: weilding manafold in reply to MAC,IL, 05-06-2004 06:32:03
Mac,
I hope you are condeming arc weld as a cast repair, because oxy/acet weld done properly is a permanent repair. The added material is the same material as the manifold . It is easy to thicken a weak or thin spot to make a better than new repair.
george
RobertTX
05-06-2004 05:47:42
There are typically two rods available at the welder supply. The Ni 99 has a higher nickel content and lower yield strength. It is best for small parts such as your manifold because it will tend to yield before the casting can crack if stresses get high. The Ni 55 is a higher strength material and is best suited for larger parts. Both work very well on AC. The preheat procedure one of the other guys suggested is good, the basic method is to weld a little and peen a lot, then repeat.
mj
05-06-2004 02:23:40
If it's on a running tractor where you can get to the crack just clean the area good with a wire brush and start the engine to preheat the manifold, shut motor down and then weld with some hi-nickel rod. Start engine to equalize temperature of manifold and you're finished. If you have the manifold off clean cracked area (don't use an abrasive wheel as this will impart impurities into the weld) and preheat evenly with a torch, weld and reheat with light peening around weld. Cover with sand and allow to cool.
george md
05-05-2004 23:18:25
Vince,
To do a good job on a manifold , I would forget about the arc welder and get out the torch. Get some cast iron rod ( square rod that is cast iron in a stick) and a can of flux . Arc weld is the worst choice to weld cast , next best is brazing , and the best choice is oxy/acetylene cast iron weld . Here is a link to some cast iron repair and some other things .
george
Charles (in GA)
05-05-2004 19:06:21
They make a special cast iron rod, pretty common.
Charles
