OK guys, I need some advice on a problem I am having with an automobile.I bought an 87 Mustang 5.0 2 years ago, and while it has been a good car, and fun to drive, there is a persistent shimmy in the front end that is hard to diagnose. I drove the car 2500 miles cross country two autumns ago, and during the trip there would be periods of annoying vibration from the front end, and the steering wheel would oscillate side to side. Sometimes it was very bad, sometimes barely noticeable. After the trip, I noticed the front tires were feathering at the edges. These were installed brand new before the trip. I suspected loose wheel bearings, and I was right. When I took off the wheels, I could get about 3/16 deflection on the rotors by pulling on them side to side. I replaced the bearings and snugged them up, but the oscillation persists. Thinking that maybe the tires hadn't been properly balanced at the store I bought them from, or maybe a wheel was bent (alloy rims) I rotated the tires front to back, but still there is a shimmy. The wheel will shake left-right-left-right at highway speeds. Sometimes when crawling along the freeway during rush hour, when I am braking at low speed, the steering wheel, and the car, will pull slightly left. Also, a hard application of the brakes will sometimes result in a noticeable veering to the left. All ball joints seem ok. Tie rods ends seem snug. I am wondering if the steering rack is bad, as there is a slight click when moving the steering wheel (although it feels like it is in the column). Are there inner tie rod ends on the steering rack, and can they be replaced? Would bad ball joints cause a shimmy? Also, the manual I bought for the car says the ball joints are not replaceable, and that you must replace the whole control arm at about $300 a pop, yet a local auto store stocks replacement ball joints for this car. I would just bring it to a shop if money wasn't an issue right now (back in school), but I am doing all my own maintenance for the forseeable future (replaced a heater core last fall, 8 hours! And just after recharing my AC.....) A 5.0l v8 doesn't make a lot of sense right now, especially with gas at $3.80 a gallon, but I would like to keep this car to have some fun with in a few years time ( 460 v8.....heads....pipes....)
