Pickup axles under trailer?
Chris
09-24-2000 10:27:18
Has anyone given any thought to using pickup axles for a light duty car trailer. I have a pair with springs and hangers. would plan on 16 footer with a dovetail.and enough channel iron for it. Any ideas would be appriecated thanks.Chris
Halsey Green
09-25-2000 05:47:16
 Re: pickup axles under trailer? in reply to Chris , 09-24-2000 10:27:18
One thing to watch for - if you are using semi-floating axles, the "c" clips that hold the axles shaft in the differential can come off and let the axle shaft come out of the axle housing. the use of full floating axles will work and you can remove the differential and even cut off the axle shafts. Hope this helps.
paul
09-24-2000 19:41:56
I'm sure it's been done, but wouldn't it get pretty high & kind of on the heavy side?
--->Paul
tim
09-24-2000 20:14:37
 Re: Re: pickup axles under trailer? in reply to paul, 09-24-2000 19:41:56
i built a trailer with two 3/4 ton ford rears with the centers cut out and put hydraulic brakes on them and used it for 10-12 years till i got a gooseneck. i put my deck over the tires so it was high for cars but worked good for hay and tractors.....
Nathan(GA)
09-25-2000 08:21:19
 Re: Re: Re: pickup axles under trailer? in reply to tim, 09-24-2000 20:14:37
Tim, How did you activate the brakes, with a tongue actuator or what? How smooth was the braking?
Thanks, Nathan
tim
09-25-2000 18:33:49
 Re: Re: Re: Re: pickup axles under trailer? in reply to Nathan(GA), 09-25-2000 08:21:19
i used a surge brake in the tongue it all worked good except you had to locck it out to back up a hard grade or the brakes would come on.
