Tool Talk Discussion Forum
winches
Jerry L /az
05-03-2004 18:16:53
I have a 10,000 lb equipment trailer that I got with my tractor. I'm fixing it up needs to be rewired,lights ect. I'm thinking of mounting a winch on it. need at least 6.000 lb pull capicity, I've seen the portable ones that the off roaders use are they any good? can anyone recommend a good winch? don't want to spend 1,200 for one..... .thanks Jer
Bill
05-06-2004 16:34:02
 Re: winches in reply to Jerry L /az, 05-03-2004 18:16:53
Pierce...Often overlooked... LOVE mine/priced reasonable. Have used it heavy for many years now & Pierce sells the same unit all these years. Just my 2 cents. GOOD LUCK!!!!! !!!
Jerry L /az
05-04-2004 17:15:51
Thanks thats the information I was looking for..... ..... ....Jer
glenshoe
05-04-2004 08:34:08
Jerry, I have a Superwinch S4500 (4500 lbs?) that was given to me and I had to have it repaired which Superwinch did at minimal cost. They're good people to deal with. Anyway, I've winched a number of loads up on my trailer including a 5000# tractor up very short steep ramps with no problems. Of course I used a snatch block (pulley) to cut the load in half. I have the battery right next to the winch with heavy duty cables. If I were to purchase a new winch right now, I would buy a bigger one. I like the looks of the 12000 lb Mile Marker winch but I would still consider Warn, Ramsey, or Superwinch. HTH, Glenn.
VADAVE
05-04-2004 06:44:03
Remember the rated pull is only acheived during the first wrape on the drum. Also if you want more pull put a sheave block (pulley) at the load and hook the cable back at the winch. This will double the pull strength; i.e. 6000# becomes 12000#.
I've been looking a Ramsey's on [email protected]. They want between $400 and $600. The drum holds about 90 feet of cable in 4 layers. Only the first layer has the 6000# pull. I was surprised to see they draw almost 300 amps--you'll need a battery close by.
RogeR
05-04-2004 06:08:39
Hi Jerry;
Search the archives- this has been discussed before.
Good luck,
Roger R
Coloken
05-04-2004 05:57:58
Jerry, go ahead and spring for about 400 dollars plus for a good winch. You will never regret it. Ramsey, Warn, super winch, etc.
rustyfarmall
05-04-2004 04:42:46
I have seen a couple of those 6,000# winches in action, or maybe I should say attempted action. The first one was an attempt to winch a 1979 Monte Carlo onto a car trailer. The Monte was minus the engine and trans, plus a few other parts, and I had to push with a tractor to get the job done. The second experience was trying to load a 1/2 ton Ford, which was a bit heavier than the Monte, but the truck was sitting on a bank, so it was more of a downhill pull. In this case, two of us had to get behind the truck and put our backs into it to get the truck onto the trailer. Keep in mind that the truck weighed about 4,500#, and was a downhill pull. The winch was rated at 6,000#, and would not pull the truck. Stay away from the cheapy winches.
Ibby
05-04-2004 03:17:48
I've had good luck with the Superwinch brand. Much less money than Warn or Ramsey. Easily rebuilt if you wear one out.
