Tool Talk Discussion Forum
electric fence
Doug
05-03-2004 06:58:17
Will be getting a few calves this week and need to know correct spacing between wires. I already have a five wire fence up with barbless twisted wire on it. I'll be getting light weight calves (350 - 400#) and want to put up a couple of hot wires so the calves don't go through the existing fence. How should I space the wires or would one wire be good enough? I don't want to find myself chasing these things around the county. Thanks in advance.
Phil in MS
05-04-2004 06:57:27
 Re: electric fence in reply to Doug, 05-03-2004 06:58:17
Paul is right. Green sale barn calves are upset about losing mama and they will hit those wire fences hard and won't let up until they run out of gas, electric fence or not. If the calves are weaned and bunk broke for 30 days that is a different story. Receiving pen should be heavy duty with wire panels or hog wire. After they stay there for several days or a week they are ready to turn out without going crazy. Good luck.
Mattlt
05-03-2004 11:36:22
Tear some old white rags into strips, then tie them around the electric fence wire, every 10 feet, or so.
These serve two purposes: 1) The calves get curious, and tend to walk up and sniff them. I think you can figure out the results. and 2) They aid in visibility of the fence. When the calves are running toward it (as they usually do) they'll have a better chance of seeing the white cloth, vs. that single strand of wire.
My two cents.
paul
05-03-2004 10:40:30
Calves in a wire strand fence. Ha. :) We all had to start somewhere - you'll learn.
Your calves will spend a few days running through that type of fence, hot or not. They are just too excited, like any kids, and too dumb, like any kids, to know better or to learn quickly.
A small pen area with cattle panels or woven wire with a hot strand above would work better to let the kids get used to the place, smells, sounds, and so on of the new place. In a few days put them in the bigger area, and at least when the walk through, they will have a feeling of 'home' by the pen area & you should be able to recapture them.
Good luck. Enjoy your learning days with this - someday you will look back at the fond memories & colorful language used & chuckle at the next fellow with this same question & what he's in for. :)
--->Paul
