Tool Talk Discussion Forum
Rose bud heating
Duke
05-01-2004 08:51:07
I bought a rose bud #10 air liquide tip for my oxy/acet torch. But I am not sure how to use it. How much pressure of acet, and how much pressure of oxy?
Light the acet first then introduce oxy, right?
GPWT
05-03-2004 10:29:34
 Re: Rose bud heating in reply to Duke, 05-01-2004 08:51:07
Duke,
Be careful with these. They use acetylene at a high rate, and can overdraw your acetylene cylinder. If that happens it becomes unstable and may explode!! You need to find out the tip's acetylene flow rate, then use the 1:10 rule in sizing your cylinder.
Example: if the tip uses 20 CFH acetylene, the cylinder must have a capacity of at least 200 CF.
L arry E
05-01-2004 21:04:13
15 psi acetylene and 18 psi oxygen.
PaulH
05-03-2004 16:08:50
 Re: Re: Rose bud heating in reply to L arry E, 05-01-2004 21:04:13
Whoa there! Acetylene becomes unstable around 15 psi. Punch the link for a description of acetylene. I use a pressure around 7 and 7 for a rosebud, but make sure the tip isn't too big for your cylinder. Too much drawdown will pull out the acetone, turning your acetylene cylinder into a bomb.
T_Bone
05-04-2004 04:13:16
 Re: Re: Re: Rose bud heating in reply to PaulH, 05-03-2004 16:08:50
Hi Duke,
I'm with Paul and GPWT as you do NOT want to use 15psi of Acetylene. I use 5 to 7psi Acet max with upto 20psi max OXy while using a rosebud.
Too much heat to quickly can cause carbon sweat or cause the carbon to rise to the surface making the surface very brittle and the enternal metal composistion depleated of carbon. To get a good view this action, overheat a scrap piece of SS.
A rosebud lites just like a cutting head preheat flame and use a neutral flame setting.
T_Bone
