Tool Talk Discussion Forum
looking for ideas on building a steel rack
Andy
04-30-2004 20:32:41
I want to build a large steel rack for angle, channel, flat,(etc) but I would also like a slot in it to slide sheetsteel,(vertically) in as well. I have a bunch of 2" sched 40 pipe I would like to use. Open to any ideas. Thanks
john d
05-02-2004 15:13:02
 Re: looking for ideas on building a steel rack in reply to Andy, 04-30-2004 20:32:41
Mine sets against the wall, and stores pieces vertically. The wall does NOT support all the weight, however. Essentially, it's a "L" shape, with the bottom of it out about 16" from the wall. Dividers make it easy to keep stuff sorted, and also brace the back support to the front of the bottom part. Nothing's going to fall unless I get very careless when taking something out of it.
Road Warrior
05-01-2004 20:27:31
third party image
I've seen lots of steel racks built out of 1" square tubing. I don't see why 2" pipe wouldn't work, as long as you get a good, solid weld joint. Gussets need to be under each "arm" for safety and strength. You can store sheet steel inside the "A" frames.
rhudson
05-01-2004 18:21:08
i agree on not using the pipe. once saw a steel rack made of 4"sch 40 with arms welded on like limbs of a tree. one day one of the upper arms pealed a tear in the pipe and cascaded down pealing the lower arms. if anyone had been between the racks, well it was like a rockslide only heaver. i like "a" framed racks built of channel with cross continous cross arms of channel. longer at bottom narrow at top so that loading with an overhead hoist is easer. just remember, tons and tons of steel will end up on the arms.
Andy
05-02-2004 08:28:37
 Re: Re: looking for ideas on building a steel rack in reply to rhudson, 05-01-2004 18:21:08
This is for a farm/hobby shop. I was thinking of having the limbs stick out 10"-12". It's basicly to keep my pile of steel,(tube, angle, flat) sorted and off the floor. I don't have a big stock. My reason for wanting to use the pipe is that I have enough laying around to make one. It will have good joints,(double cut 45 deg T joints).
jackel,ind
05-01-2004 13:47:47
i personaly would buy alot heavier material than just 2" pipe.i have 4" h beam for mine.it has a bottom leg and then a vertical welded to the end.then i welded horizontals coming out to make each shelf.
