Tool Talk Discussion Forum
What's your welder?
Paul Janke
04-30-2004 18:29:33
I was in a welder store the other day, and happened to think to ask if they sell many AC buzzboxes any more. They said most people now go for wire welders and such. Now I'm wondering if I am the only person left using one of the old ones. Mine is a 180 amp AC only Forney, one of the ones with all those different plugs for the different heat ranges. I have decided to name my welder Kathryn. It is nicknamed Kay, and I try not to use it when the weather is unpleasant because I don't have a good place to work. During that time, it is my act of Forney, Kay shun.
Taylor Lambert
05-09-2004 20:52:52
 Re: What's your welder? in reply to Paul Janke, 04-30-2004 18:29:33
I have six welders my first was a Miller Thunderbolt AC/DC when I was 14 my second was a Campell Hausfield 110 wire welder ok for some things when iwas 18 Then about 2 years ago I bought an old MillerMatic 35 wire welderwith low hours. Then the compny I worked for went under and i bought 2 3 phase machines for 180 dollars one was a Miller Goldstar DC the other was an old AC Idealarc Lincoln dual phase. Its got something wrong with it it will run on 220 but not 3 phase. But it has a problem welding 220 Ibought it to use later for a TIG welder. Right after that I bought a Miller 225 Bobcat Portable with 65 hours on it for 1200 dollars. I just weld for a living when dirt work is slow here. I found an old Hobart DC portable welder here for 200 dollars Ithought about buying to traae on it startes by running 24 volts back through the armature of the welder to start the engine.
RJ-Az
05-04-2004 20:33:46
I have a small Miller engine driven DC machine(180K)and a 110V Lincoln flux core wire machine and can weld with both machines anywhere on the homestead.
John A (TX)
05-02-2004 22:26:09
Hi, Paul:
I wasn't going to reply to this - seeing as how you've gotten a pretty good response already - but I didn't see a single Miller listed so thought I'd better get at least one represented. Mine's a plain ol' Miller Thunderbolt with the crank on top to adjust amps. Sure do like it! (But understand, I'm no expert .. just use it around the farm).
~ja
Chris-se-ILL
05-02-2004 20:39:07
We actually have 2 welders on the farm. Dad used to use an ol' Craftsman welder {to change amperage range, you selected from a series of plug-in sockets}. We haven't used that old welder since he bought the Lincoln AC/DC/DC- big (tombstone) buzzbox welder about 25 years ago {It uses a hand crank on the face to select amperage. I can't remember the full amp/range that can be selected}. The Lincoln does a really fine job of "laying a bead." However, I do want, and plan, on getting a large wire welder someday {I just like big toys! :-) }
iceman
05-02-2004 05:50:10
pure DC is what floats my boat. the stick seems to do everything well. mig is best for production work. once you use pure DC, you will never go back to a buzz box. I like the engine driven ones. they make power as a bonus. I am not a pro welder, but I play one on TV...mike
Hal/WA
05-01-2004 21:59:38
I still use the old Lincoln AC model that my Dad bought in the 60's. It works fine for most of the things I have tried and it would be hard to find a cheaper welder with that much power. I hope to get a wire feed soon, as I have tried them a couple of times and think I would have better success on thin metal.
By the way, I liked your pun, but I seem to like ALL puns!
Jackson Knight
05-01-2004 16:31:22
I bought a craftsman ac/dc last summer at sears love it does a good job.
Ken
05-01-2004 14:47:55
I have an old Montgomry Wards 350 amp AC/DC stick welder that I bought new 30 + yrs ago . Works great . I use DC mostly . I also have a Miller Cricket 110 Mig Welder that I bought new about 11 yrs ago & I just love it . It's done several body repairs .It will also weld aluminum . My buddy's a professional welder & he's had several migs but he says mine can really get serious when he uses it . He tried to locate one but they quit making it . Well that's mine . Ken C.
JT
05-01-2004 07:46:24
Here is a subject you cn get a lot of opinions on.
When I was in High school and later in College. I found I really liked the Lincoln Idealarc 250. Sometimes refered to as a Tombstone welder. The older ones are considerably better units if you get one that is AC/DC.
Wasn't until about 10 years out of college that I finaly got serious about getting my own. Wound up paying $350 right in town, I had another one located for $600 and was ready to buy it.
As for wire welders all the sales people will try to convince you that is what you need. The few times I have worked with one I had to set I didn't have good luck. I just think this means you need experience with them. I did use one in college that was fluxcore wire and a 400 amp rotary power source. Man that thing would go and go.
I like the rotary power sources a little better I also have a Hobart engine driven welder. It is rated at max output of 400 amps and has a Chrysler flathead 6 engine.
In short (to late for that now) I prefer stick welders but one of these days I will probably have a wire welder to supplement.
JM2CW
ShepFL - mine is ancient
05-01-2004 07:21:47
My welder is Lincoln Electric Lincwelder DC-250MK & DC-250MK (Aircraft Welder). I gave $25 for it and cleaned all the dirt daubers out of it and cleaned the commutor. It has been a good rig and does what I need to do. Just wish I had power to the shop by now, gas powered generator is not the best power source.
John Ne.
05-01-2004 13:03:25
 Re: Re: What's your welder? in reply to ShepFL - mine is ancient, 05-01-2004 07:21:47
I have two stick welders, a very heavy Forney, with the dial and crank on top, and a Hammet, with a wooden case, my father bought it on my uncles auction in 1954, my uncle bought it who knows where, used, in the late 30s. Still works good. I use wire on occasion at work, and still prefer a stick.
greenbeanman
05-01-2004 06:41:54
I have a Westinghouse 180 amp buzz box welder.
From experience I know that a 120 amp setting on this welder is MUCH hotter than the 120 amp setting on a Lincoln.
This old unit has a crank on top of the unit to adjust amperage settings.
My family aquired it around 1965 as a used unit for $50. Still welding just fine, but the cooling fan takes awhile to get up to speed in the winter when it is cold. Expect it needs bearings.
snitkawl
05-01-2004 05:19:27
I have a POW-CON 300 amp wire with stick and plasma cutting capablility in the same unit. Was told(by another welder manufacturer)that you couldn`t get all three in one package, but I have been using it for over 10 yrs and it works great.
Robert in W. Mi
05-02-2004 07:15:17
 Re: Re: What's your welder? in reply to snitkawl, 05-01-2004 05:19:27
I also have a POW-CON stick, mig welder! It's sure a great welder!!! I mig 99% of the time these days, as it does a great job for me, but i'm NOT a pro welder doing spl jobs of any kind.
I also have an OLD stick welder my dad bought in the 70's for $50.00. It belonged to an old gentleman friend who was selling it to get a "new style" welder! It still works like new, but the print on it was long gone when we got it, so i have no idea who made it. It has a wheel on top that you turn to set the amps up or down, and the unit is so heavy it takes 3 guys to lift it!! They sure don't make them like they use to!!! :>)
I've also owned a Onan engine driven welder, and a Lincoln engine driven welder. Man the Lincoln was nice, but i hated the Kohler motor!! It was too noisey, and too thirsty!!!
These days "if needed" i use my 15KW tractor pto gen set to power a welder away from the shop, and that way i have lots of power on site to do "what ever".
Robert
Joe Dirt
05-01-2004 04:39:32
I picked up a Lincoln AC225 a couple of years back for $25. Same kind that I learned to weld on as a kid.
TimV
04-30-2004 21:15:47
I've got a Hobart Handler 135 Mig with gas (though I do use flux-core on occasion) for thin stuff, and a Lincoln AC225 for everything else. It's a nice one-two punch, and though I'd probably use DC capability if I had it, for the stuff I do this combo gets me through fine. By the way Paul, that is without a doubt the worst pun I've seen on these boards in quite some time, which (considering the bunch of punny guys that hang out here) I think could be considered a compliment..... :-)
RusselAZ
04-30-2004 21:02:55
I have two old Forney 180 amp welders. The first one was old when I got it in 1974 for 75.00. It had the new helment and cables that the guy that traded it in didn't want to take along with his new one. About a month later he wanted his Forney back. My second Forney I got in a pawn shop for 50.00. It has a battery charger built in. I love these old Forney's as they were designed to pull low amperage off the line, such as early farms had, and held a very stable arc. The only draw back is they will NOT weld with 7018 rod but 7014 or 7024 works wonderfully. My first Forney is proably the most abused tool I have. For years I didn't have an acetylene cutting torch and I used it on high heat to burn cuts with and ran it a lot with a carbon arc torch. Both of these operate just fine on a 30 amp breaker, even on 180 amp output. Duty cycle? who knows but they keep up with me.
My third welder is a sears wire welder. Just a nice little thing that I use flux wire with, though it will use gas, mostly for welding thin wall material.
kyhayman
05-01-2004 07:03:23
 Re: Re: What's your welder? in reply to RusselAZ, 04-30-2004 21:02:55
Try a Lincoln Excalibur 7018, still not as good as on a DC but I do use them with my Forney when I need the 7018 properties.
A follow up
04-30-2004 21:09:51
In case anyone is needing a good welder, here is one on Ebay with 5 days to go. well worth the price is you can get it and the shipping for less than 250. Remember they are wound with copper so are heavy. A guess is 150 lbs for this one. the leads probably are another 50 but could be shipped separately.
3813096553 Ebay item #
Ray,IN
04-30-2004 20:42:27
I have and use a Lincwelder 225A, AC/DC gasoline powered welder and a Lincoln 180A AC buzz box. The Lincwelder is well worth the price. I can take it wherever it's needed, hauling it with a tractor where the 4WD truck can't( or I don't want it to) travel.
John *.?-!.* cub owner
04-30-2004 20:18:31
My welding is only occasional, and my welder is a used Lincoln AC unit I bought 20+ years ago. A few years ago I was at a salvage yard that was recking some telephone company battery chargers, and I purchased some of the diodes from them (600 amp). I wired a set of them to the output of my Lincoln, and it sure makes a nice set up for my use. Also bought a cheap auto darkening helmet. It doesn't make my welding any better, but it makes it easier.
Road Warrior
04-30-2004 19:51:41
I've got a Lincoln AC/DC that I use a lot. I'd love to have a wire feed too, but can't justify the money. As for speed and cleanliness, wire feed is really nice, in certain applications.
john in la
04-30-2004 18:49:15
I also have a Lincoln AC only buzz box. Works great for what I do.(but I do know how to weld in all positions with stick mild steel) Would rather I had bought a DC model for easier overhead.
I hear tell the new wire feed is easier to use and think this drives their popularity up. But I know nothing about them. Use to be they were for mig and tig only or so I thought.
Chuck MI
04-30-2004 20:03:44
 Re: Re: What's your welder? in reply to john in la, 04-30-2004 18:49:15
Wire feed are easier to make nice looking bead, but make sure there's good penetration underneath.
wdTom
04-30-2004 18:37:20
I have a Lincoln "buzz box", 225 amp that belonged to the farm I worked on when I was a kid, mid to late 60s. It is a good one, will never sell it. However I have on order a Lincoln "Precision TIG 185" which I guess would have to be my dream welder. It is a AC/DC machine that will do aluminum and has "pulse". It will go as low as 5 amps and up to 185. I can hardly wait to get it and set up. I need to wait at least 2 more weeks, dealer says they have sold a bunch on a spring sale and mine isn't due to ship to May 10.
Mark
04-30-2004 19:19:53
 Re: Re: What's your welder? in reply to wdTom, 04-30-2004 18:37:20
I have a Lincoln 'buzz box' too. Bought it for $85.00 bucks. You couldn't get me to part with it. But I have to tell the truth, ever since I bought that Hobart MIG the Lincoln hasn't moved.
jackel,ind
05-01-2004 13:38:58
 Re: Re: Re: What's your welder? in reply to Mark, 04-30-2004 19:19:53
i have a 225 lincoln.a/c i got it out of the high school.works great.i have a miller 135 wire welder.
i want to get a big miller power source so i can tig and run a bigger wire feed.like i use at work
