Tool Talk Discussion Forum
Well
Jeremy Brault
04-29-2004 19:39:59
I was wondering about our well at home. we got a pressure switch on the well it self, and one in the house on the pressure tank. My problem is that i wanna take water from the well for thwe power washer, but there is no pressure there, because the pressure tank stops the well. so could a guy disable the pressure switch in the house and use the one on the well, so when u opened the water spicket on the well it would kick in and run. Right now i take out the check valve in the house so it will back feed, but gets air in the lines in the house. If i can do this how would i do it, or what is the easiest way to do it.
Thanks, any help would be great
Jeremy
buickanddeere
04-30-2004 14:19:59
 Re: Well in reply to Jeremy Brault, 04-29-2004 19:39:59
Why not take the water from the tank instead of the line between the tank and well? Pressure washing is a lot more successful any ways if a ceramic plunger pump is used and the washer's supply connected to the hot water tap.
Matt K
04-30-2004 06:24:58
If the check valve you are removing is between the well and the pressure tank, then move that check valve to the well, install it ahead of the spigot, so that the spigot and the pressure tank are on the same side of the check valve, and the well is on the other side. You should have a check valve between the pressure tank and the house plumbing too.
W--cv--t--(line to house)--t--cv--house plumbing / / s pt
W = well
cv = check valve
t = tee
s = spigot
pt = pressure tank
With this setup there's no need to make changes to any controls. The spigot will always have pressure from the tank, and the pressure switch on the tank will always control the well.
Matt K
04-30-2004 06:26:42
 Re: Re: Well in reply to Matt K, 04-30-2004 06:24:58
My little diagram didn't quite turn out. The first 't' should be connected to the 's' and the second 't' should be connected to the 'pt'
Gary in tx
04-30-2004 09:01:28
 Re: Re: Re: Well in reply to Matt K, 04-30-2004 06:26:42
And the thigh bone connected to ankle bone and the ankle bone connected to tha foot bone..... ..... ..... ..... ..
Sorry could resist putting a little humor in here.
Charles (in GA)
04-30-2004 04:34:30
Do you have a booster pump??? I can see having two pressure switches if one operates the booster (at the tank/house and one operates the well pump (at the well, but it too needs a tank to operate properly.
Otherwise, why do you have two pressure switches?
Charles
Jeremy Brault
05-01-2004 18:06:30
 Re: Re: Well in reply to Charles (in GA), 04-30-2004 04:34:30
No booster pump is in there.
