Unsticking a stuck block
WEL
09-23-2000 15:33:52
After the head is pulled what, in your opinion, is the best way to unstick a stuck block. What penetrant to use. Any particular procedure? All suggestions appreciated.
Richard Kirk
01-18-2004 14:23:15
 Re: Unsticking a stuck block in reply to WEL, 09-23-2000 15:33:52
pour coca-cola into the cylindar
dick
09-24-2000 06:18:33
I have had excellent results with Kroil from Kano Labs in Nashville, TN. Kroil unstuck the cylinders in my '52 John Deere G. I put a gallon in it, let is set over the winter. The next spring I pulled the head, cleaned out the glop from the rh cylinder and put a pry bar between the starter nose cone and the flywheel. It broke loose with little effort. That tractor had been sitting out side for 15 years!
Vinegar Desolves Rust!!
09-24-2000 12:19:45
 Re: Re: Unsticking a stuck block in reply to dick, 09-24-2000 06:18:33
Hi dick, Vinegar does a great job of desolving rust. It leaves a black oxide that can be washed away. Thats provided the engine is stuck just because of rust. It could have been a bearing problem too so I always pop the rod and main caps loose.
Some people will suggest salt and vinegar but this causes steel etching and produces a off-gas of hydrogen gas. This will cause more problems and I suggest you don't use it!
Time seams to be the big factor no matter what you use on the rust.
T_Bone
Dean
09-24-2000 04:56:51
I've had real good luck with PB Blaster. It's a terrific penetrant.
Good luck!
Dave
09-23-2000 16:29:11
Oil, like the MMO mentioned, in the cylinders and lots of time. You use a wood block and a hammer and try to get the pistons to move by tapping them. Don't hit too hard. If it's a tractor you could try putting it in high gear and rocking the rear wheels. Or if you have a crank, try this: I heard of one guy who put a jack under the crank, and the weight of the tractor pushing down on the crank plus the oil in the cylinders soaking over a few weeks eventually turned the engine. Good luck. Be patient.
Jim
09-23-2000 15:46:17
Although I have never tried this I have heard from more than one source that if you pour Marvel Mystery Oil in the cylinders and let it set for a few days that seems to always work better than rust penetrants.
