Tool Talk Discussion Forum
Welding a crankshaft, small engine.
greenbeanman, K
04-28-2004 09:40:06
When I was in high school industrial arts class, I welded the tip of a crankshaft back onto a 21C Massey Harris combine. Successfully I might add.
I now find myself with the tip broken off of an 8 h.p. Acme diesel generator engine, nearly flush with the oil seal.
Any thoughts about removing the crankshaft, aligning the two parts with a 3/8" pin hole that just happens to be in each, then welding and smoothing the joint?
The engine is low hours and I would like to get it back in use. A new crankshaft is out of the question due to VERY HIGH cost.
john d
04-29-2004 20:07:19
 Re: Welding a crankshaft, small engine. in reply to greenbeanman, Kansas, 04-28-2004 09:40:06
I'm in agreement with previous posters on getting the crank to a professional shop.
On the chance that you can't find someone willing to put the end of it back on, you MIGHT be able to chuck it into a lathe, and drill that 3/8" hole enough larger to allow a 7/16" tap to put some threads into the end of the crank. Then you could drill the broken tip to 7/16" and pull it all back together with a grade 8 bolt.
Ron(NWOH)
04-29-2004 16:52:00
take it to a auto machine shop that welds an grinds cranks they should be able to help you
greenbeanman
04-29-2004 18:59:53
 Re: Re: Welding a crankshaft, small engine. in reply to Ron(NWOH), 04-29-2004 16:52:00
I hadn't thought of a shop that does cranks.
I was just thinking of taking it to a welding and machine shop.
Thanks for the heads up. I seek one out.
markct
04-28-2004 12:47:27
well some will say it wont hold, but what do ya have to lose, i have done simular repairs on different shafts, some failed, most held tho. if it were mine i would give it a shot and see how it works
greenbeanman
04-29-2004 03:27:47
 Re: Re: Welding a crankshaft, small engine. in reply to markct, 04-28-2004 12:47:27
Thanks. This is one job that I may leave to the welding/machine shop rather than do myself.
Bruce
04-29-2004 05:39:56
 Re: Re: Re: Welding a crankshaft, small engine. in reply to greenbeanman, 04-29-2004 03:27:47
If you have a large enough oven, preheat your parts and then cool very slowly in the oven after welding, say 24 hours,should work fine.
