Tool Talk Discussion Forum
Thread tap help needed
rossow (mn)
04-27-2004 09:44:27
Can someone clarify the difference between a taper tap, a plug tap and a bottom tap? I need to expand my tap set into some odd sizes for gun work, but I don't know which type is for what sort of work. Thanks.
Fred OH
04-28-2004 08:09:07
 Re: Thread tap help needed in reply to rossow (mn), 04-27-2004 09:44:27
Like the guys say...taper for easiest starting to get the tap straight with the hole. The plug tap is close enough to be used universally...for starting and bottoming. Bottoming is used if you can't drill the hole any deeper and need all the strength you can get. A word of caution though...Gun threads are different from USS and SAE threads. Find you a chart and look at the threads that the gun men use. I think they use a lot of fine threads. Fred OH
charley
04-27-2004 17:48:25
a taper tap is used to thread a new hole that does not have threads allready.they have a long gradual taper a bottoming tap has no taper to it they work excelent for cleaning threads in a blind hole (like an engine block. this is because they have the same O.D from the begging to the end,this way they tap the complete hole a plug tap is the most common,will only cut the threads partway through, so it should be followed by a bottoming tap
Dave_Id
04-27-2004 19:31:16
 Re: Re: Thread tap help needed in reply to charley, 04-27-2004 17:48:25
Drill the hole deeper, and you won't need a bottoming tap
Greg S
04-27-2004 12:11:34
Try this link Link
