Tool Talk Discussion Forum
mig welder
jeff
04-26-2004 16:57:50
I am trying to decide between the lincoln pro-mig 135 and the hobart handler 135 mig welders.are they made in in the u.s.a. or overseas? they are about the same price and it"s hard to pick one over the other,so i would like to hear your comments good or bad on each.
Scott v
04-29-2004 11:01:45
 Re: mig welder in reply to jeff, 04-26-2004 16:57:50
Jeff, Hobart has a new 140 mig out that should be pretty good.
The sp 135 plus is really the very nicest little mig going.The infinite control beats wire feed tracking four tap design hands dowm.It is not too bad really with the tap style but when you get into the miller 135 with infinite control with wire-feed tracking it really is a answer to a problem that did not exist.Same goes with the 175 machines.
DumOleBob
04-27-2004 07:59:46
Your question is like who makes the best pickup: Ford, Chevrolet, Dodge? It all depends...
I've got a Hobart 135 and a Miller 250 both of which do good work. My buddy has a Lincoln & wouldn't think of changing.
Bottom line - go with the best dealer who will support what ever you buy!
Chris
04-27-2004 03:14:06
Another vote for Hobart, which by the way my dealer told me was built to spec by Miller! I have also been using Miller consumables in my mig torch with no problems- they interchange perfectly.
TimV
04-26-2004 19:13:07
Jeff: Here's another vote for the Hobart. I've had mine about 5 years, and have been very satisfied. As you're probably aware, Miller owns Hobart, and some parts interchange. For instance, my Hobart came with a Miller gun on it (which was fine--the Miller gun is better than the Hobart one anyway). I use gas and solid wire unless I'm going to be welding outside, which isn't often.
Van in AR
04-26-2004 18:25:49
Have had a Hobart handler 135 for about four years and I am very pleased with it. I use the CO2 gas. I was not as happy with the flux corred wire but it works good either way. The gas does a better job with light materials.
Van
stotinga
04-26-2004 19:14:00
 Re: Re: mig welder in reply to Van in AR, 04-26-2004 18:25:49
I have owned all three brands. The Miller is the best by far, the Hobart is very good also, the Lincoln I had was pretty much junk. It was in the shop about as much as I used it. Sent back to the factory twice. I didn't get much factory support on it either. I bought it because I have a Lincoln stick welder that can't be beat. The mig wasn't very good
Van in AR
04-26-2004 18:25:23
Have had a Hobart handler 135 for about four years and I am very pleased with it. I use the CO2 gas. I was not as happy with the flux corred wire but it work good either way. The gas does a better job with light materials.
Van
walt
04-26-2004 17:34:55
I have had the Hobart now for about 4yrs, very pleased. First project was a welding cart. But I have seen lots of sales where they throw in the cart. Using gas instead of the flux core wire.
wdTom
04-26-2004 17:01:30
I just bought a TIG welder and I decided on Lincoln. In doing some "research" on discussion forums got a comment that Miller made the best MIGs and Lincoln was tops in TIG. Take it for what is worth. Might be worth checking out Miller's products.
