PLASTI-DIP
jake from il
10-06-1998 20:36:24
Just bought a can of plasti dip from ace hardware
diped some tool handles. im thinking of brushing it on tractor running boards
any exeriances with the stuff?
DaBrow
10-07-1998 09:19:17
 Re: PLASTI-DIP in reply to jake from il, 10-06-1998 20:36:24
: Just bought a can of plasti dip from ace hardware
: diped some tool handles. im thinking of brushing it on tractor running boards
: any exeriances with the stuff?
I've used it at work on tool handles as well. Yes it gives a smooth finish and bonds to steel well BUT with a little oil on your boots it may be slippery. Just my 2 cents worth(and those are Cdn cents) DaBrow ps If you try it post a note for us less adventurous. It can be peeled off.
Wild Bill
10-07-1998 19:08:51
 Re: Re: PLASTI-DIP in reply to DaBrow, 10-07-1998 09:19:17
: : Just bought a can of plasti dip from ace hardware
: : diped some tool handles. im thinking of brushing it on tractor running boards
: : any exeriances with the stuff?
: I've used it at work on tool handles as well. Yes it gives a smooth finish and bonds to steel well BUT with a little oil on your boots it may be slippery. Just my 2 cents worth(and those are Cdn cents) DaBrow ps If you try it post a note for us less adventurous. It can be peeled off.
I dipped a few pairs of pliers in it, it didn't hold up as well as "factory" handles. Running boards? What the hell, give it a try. Like DaBrow says, let us how it works.
scott haasl
09-08-1999 13:01:43
 Re: Re: Re: PLASTI-DIP in reply to Wild Bill, 10-07-1998 19:08:51
: : : Just bought a can of plasti dip from ace hardware
: : : diped some tool handles. im thinking of brushing it on tractor running boards
: : : any exeriances with the stuff?
: : I've used it at work on tool handles as well. Yes it gives a smooth finish and bonds to steel well BUT with a little oil on your boots it may be slippery. Just my 2 cents worth(and those are Cdn cents) DaBrow ps If you try it post a note for us less adventurous. It can be peeled off.
: I dipped a few pairs of pliers in it, it didn't hold up as well as "factory" handles. Running boards? What the hell, give it a try. Like DaBrow says, let us how it works.
deb
02-24-2004 17:30:09
 Re: Re: Re: Re: PLASTI-DIP in reply to scott haasl , 09-08-1999 13:01:43
I wonder if I can brush on clear Plasti-Dip to protect a small table top. I don't want a separate glass table top piece, but need a durable finish. I have read about 2-part, pour-on finishes (Enviro-Tex), but would rather control it with a brush. Maybe need several coats to get a thick finish? Also, is CLEAR Plasti-Dip really colorless? Thanks
Mongo
10-10-1998 20:23:30
The problem is that it's sorta rubbery even after it dries, this causes it to peel.
If you want something for the running boards that is pretty tough (made for putting on concrete or steel and driving forklifts on) try the Rustoleum epoxy floor paint. I've personally put this stuff down on clean steel and rolled agregate (sand) into it for extra traction when it's raining and so far the only thing to wear out is the shoe leather.
They made a couple of versions so make sure you get the heavy duty stuff (and supply your own "Kiddy play sand"). Also, be sure to put it on clean steel or concrete for best adhesion to the surface.
