Tool Talk Discussion Forum
Tankless Water Heaters
Laplast
04-22-2004 05:07:14
My water heater is at the age where I should start thinking about replacement in a few years before trouble develops. I have been hearing a lot about the tankless heaters than only supply hot water on demand. They claim they do not waste heating water 24/7 reguardless if it is needed or not, and as a result you save 25 to 50% on you water heater bill.
1. Have any of you installed them 2. Is the water hot enough when used 3. Are the energy saving enough to justify the higher cost 4. Would you recconmend them 5. What brand THANKS for your help!
Nolan
04-27-2004 06:32:45
 Re: Tankless Water Heaters in reply to Laplast, 04-22-2004 05:07:14
I've got one in my house. It's a little different in that it's not a stand alone unit, it's part of my oil furnace, and has a 2 gallon in furnace tank. It's not just a set of windings.
I like having unlimited hot water. I like not having a water tank taking up space. I like only heating the water I use and need.
I do not like firing off the complete furnace to take a shower. I do not like the temperature fluctuations I get when taking a shower as the system kicks the furnace on and off.
Something to consider is if you've got someone who likes taking long hot showers. As in the type that only stops when the hot water tank is empty. My wife is that way and is in heaven with this system. She now takes showers for the full length of time she wants, which is generally well over an hour each day. If I were on city water, that cost would be high.
Paul Janke
04-24-2004 10:43:33
Maybe the new ones are better, but when I saw some which were new 15 years ago, they had more drawbacks than advantages in my opinion. 1. They won't kick on until a minimum flow rate is reached. 2. The temperature of the water varies with the flow rate, because the heating element is not varied. 3. If they are point-of-use, you need one for each and every place you use hot water. If there is just one central heater, a second use turned on during the time it is already being used will change the temperature. (This ties in with the previous point.) Showers could be quite an experience if the washing machine or dishwasher suddenly called for hot water. I would not choose this system even if the price were lower than a conventional water heater. Paul
Gene Davis (Ga.)
04-23-2004 18:25:10
Considered this option couple of years ago when we did a major renovation on our home. Concluded it was cheaper and simpler in the long run to install a quick recovery type electric on each end of the house, and that way there was almost no delay for hot water and it could operate for about 15 years each to equal the cost of the one tankless and installation price, plus natural gas cost more here than electricity.
EngineerJoyce
04-23-2004 10:19:40
I suggest you do a site search. Seen this topic come up several times on different boards.
Most of these replies are negative, most I have read before were positive.
1. Build-up is dependent upon water hardness or purity.
2. The "hot water lag" would be there with a conventional heater.
3. Hot water sitting in the pipes to heat the spaces would be the same with a conventional.
The biggest positive I have heard/read for a tankless is that you NEVER run out of hot water. I thought about using one when we built a couple years ago, but decided not. Why?
1. Electric is cheap here.
2. tankless cost 4x's conventional, would never return my purchase price.
3. we are a low water consumption family and never have run out of hot water with our conventional tank.
Research the option, go with what's best for your particular application.
buickanddeere
04-22-2004 15:56:21
The closer your conventional hot water heater is to the point of use, the less a tankless unit saves. Needs a heavy power feed as well. 60.0 amps or more at 240vac. The twits who designed this house require dumping 1-1/2 gallons from the bathrooms and 2-1/4 gallons from the kitchen sink before hot water appears. Water that had at one time heated. Not so bad in winter but a double loss in the summer.The AC runs to cool the house spaces that the hot water in the pipes had heated.
CJ
04-23-2004 11:04:13
 Re: Re: Tankless Water Heaters in reply to buickanddeere, 04-22-2004 15:56:21
Why wouldn't you insulate your pipes????? ????? There's insulation made right for that purpose, and it works!! CJ
buickanddeere
04-24-2004 00:20:06
 Re: Re: Re: Tankless Water Heaters in reply to CJ, 04-23-2004 11:04:13
It's a 30 year old house. Was able to use that black split foam stuff at the tank before the pipe disappeared into the drywall ceiling. Did both hot and cold pipes. During bathroom renovations I was able to slide about 15' of insulation down the pipes towards the tank between the joists. Then insulated both new bathrooms where possible. Still leaves the hot water run down the length of the house through the joists to the kitchen. The bathrooms have lukewarm to hot water if used within an hour. The kitchen is a loss however, that pipe runs right along a north west outside wall almost at the top of the wall. There must be a little air ingress from outside because that hot water felt mighty cold last winter.
CJ
04-27-2004 08:03:32
 Re: Re: Re: Re: Tankless Water Heaters in reply to buickanddeere, 04-24-2004 00:20:06
I wonder if you could drill some small holes, and have the area foamed? Might end up being cost efective in the long term?
CJ
Jet9N
04-22-2004 16:36:08
Used to have to same problem until I put in a
circulating loop. A pump to bring the hot water
to the area of use and return to the cold water side of the heater. Also put a check valve into
the circuit so cold water can't short cut to the hot water taps. Turn this pump on 1/2 to 1 minute
before turning on the hot water faucet. I just
used a manual switch, but thought about putting on
a timer so I wouldn't have to remember to turn it
off.
HTH
Jet
buickanddeere
04-23-2004 05:04:54
 Re: Re: Re: Tankless Water Heaters in reply to Jet9N, 04-22-2004 16:36:08
The circulating loop eliminates the wait time and putting unused water down the drain. However heat losses would be just as high with momentary usage and much higher on continuous circulation. A return line using just convection flow and a check valve would eliminate the need for a pump.
DaveInMI
04-22-2004 10:27:09
HVAC guy and I were just talking about this. His criticism was that lime builds fast and must be flushed out often.
John *.?-!.* cub owner
04-22-2004 06:04:48
I looked into them a while back, and the one thing I noticed aobut their savings claims was that they were comparing to an uninsulted or poorly insulated water heater. When comparing their cost to a modern insulated heater the savings are considerably less.
